Uploading a small program
Don_O
Practice run.  I have a problem to submit to the Forum later, but FIRST wanted to try and paste/upload a small program.
[fortran]!  helloworld.f90
program helloworld
implicit none
write (*,*) 'Hello World'
end program helloworld [/fortran]
Printout # 1
Height       Maximum Error
  (km)                (mm)
 380000           0.000285
   36000           0.000038
   20000           0.000019
   10000           0.000014
     5000           0.000009
     1000           0.000006
       500           0.000005
       100           0.000005
         50           0.000005
         10           0.000006
        -10           0.000005
       -50           0.000005
      -100           0.000005
      -500           0.000004
    -1000           0.000005
    -2000           0.000004
    -3000           0.000004
    -4000           0.000005
SergeyKostrov
Valued Contributor II
>>... I have a problem to submit to the Forum... What problem(s) did you have? Was it with submittion of source files, or something else?
Don_O
Hi Sergey, it was an unrelated problem and I've put it aside for the moment.
Regarding the different ways of putting information in messages, I will try and upload that "helloworld" program again - after typing this message.
So I really have only one question left: What is the best way to insert an output data printout of 20 lines or so, like the one I put in my original post? I had moved that short printout from a Notepad file "temp.out" to a Word file "temp.docx" and then pasted it via the "Word" icon on the toolbar above. It's not a big deal but I'd like to make the printout more "compact" in the future, if there is any way to do it.
Don
IanH
I find the plain syntax highlighting (see the instructions underneath the edit box) useful for that.
[plain]
  (km)                (mm)
 380000           0.000285
   36000           0.000038
   20000           0.000019
   10000           0.000014
     5000           0.000009
     1000           0.000006
       500           0.000005
       100           0.000005
[/plain]
The forum gets a bit confused about line endings/line spacing occasionally.
Don_O
Thanks Ian!  That is very compact and much closer to what I was aiming for.
Don
