Use OpenMP to parallelize different source file
Liang_W_1
I tried to parallelize the Fortran codes using OpenMP. When I put all the subroutines in one single source file and created a static library, then I came into problem to run my model with this static library. But when I separate the subroutines that do the parallelization, and compile the rest of them as a static library. Using this library and those parallelization subroutines to created a new project, then I am able to run my model. That sounds weird but dose any one have the same issue?
Many thanks
Steven_L_Intel1
Do you compile all the code with the OpenMP option enabled? Are you able to provide a small test case that shows the problem?
Liang_W_1
Hello, Steve
I have double checked my codes and I found that the Coarrays option under Language tab has to be enabled. Now I am running the models.
The corresponding links can be found as follows,
https://software.intel.com/en-us/node/590553
Thank you,
Liang
Steven_L_Intel1
That's coarrays, not OpenMP. VERY different parallelzation concept. Which are you using in your own application?
Liang_W_1
Sorry, I messed up the idea. I shouldn't enable coarray since it is not recommended when using OpenMP.
