29386 Discussions
Use -qopenmp without openmp directive cause wrong result
Jsfaraway
Hi, my code will has a different result when use -qopenmp with ifort. But I haven't add any openmp parallel zone, it should just run as serial. What could cause this error? Any suggestion is appreciated, thank you!
compiler error: ifort 2021.4
Barbara_P_Intel
There is not enough information here to give any suggestions other that to try the current release of ifort. It's 2021.12.0. It was released a few weeks ago.
If you still have a problem, please post a small reproducer.
Mark_Lewy
Valued Contributor I
-qopenmp implies -auto.  If you have any code that relies on variables being implicitly saved that is likely to break if you use -qopenmp.
