User Manual or Reference
emersonone
Steve,
Do you have print-out language user's manual for order or downloadable pdf manual for reference.
Another silly question is after I compile all files, I cannot find excute/run menu (excute ***.exe)in under BUILD pull down menu since I am not familiar with Visual Studio. Does it mean we should use commend line to excute exe file?
Emerson
Emerson,
There is no printed manual available for sale. Some of the manuals are provided as PDF in the "docs" subfolder of the compiler install, but some are CHM only.
You'll find the "Start" command under the Debug menu. You can start the application with or without the debugger.
