29614 Discussions
User defined default dialog button
Intel_C_Intel
I have a dialog with three buttons -
Overwrite, Append & Cancel
Normally Overwrite is the default and is checked as being the default button.
For some applications I want the Append button to be the default.
I added iret=SetFocus(GetDlgItem(hWnd,IDC_APPEND))
Now the Overwrite button has a thicked border, the Append button has a dashed line around it but when I press Return Overwrite is activated.
I then tried adding a invisible default button IDC_RETURN but this does not help.
How can I change the default button?
David
	integer*4 function OverwriteProc(hwnd, message, wParam, lParam)
	!MS$ATTRIBUTES STDCALL, ALIAS : '_OverwriteProc@16' :: OverwriteProc
	! for Overwrite Dialog
	use dfwin
	include 'resource.fd'
	integer*4	hwnd, message, wParam, lParam
	integer*4	iret,iCtrl,imess,idControl
	logical*4	lret
	! Unreferenced variables
    lparam = lparam
    select case (message)
    case (WM_INITDIALOG)
		OverwriteProc = 1
		return
    case (WM_SHOWWINDOW)
		if (wParam) then
			iret=ShowCursor(.TRUE.)
		endif
        OverwriteProc = 1
        return
    case (WM_COMMAND)                       ! message: received a command
		iCtrl=LOWORD(wParam)
		iMess=HIWORD(wParam)
		OverwriteProc = 1
		if (imess==EN_SETFOCUS) then
			IDControl=iCtrl					! for Return
		elseif (imess==EN_CHANGE) then
			OverwriteProc = 0
			return
		end if
		select case (iCtrl)
		case (IDC_OVERWRITE)
			lret=EndDialog(hWnd,2)
                        OverwriteProc = 1
		case (IDC_APPEND)
			lret=EndDialog(hWnd,1)
                        OverwriteProc = 1
		case (IDCANCEL)
                        lret = EndDialog(hWnd, 0)
                        OverwriteProc = 1
		case (IDC_RETURN)	! pressed Return
			select case (IDControl)
				lret=SendMessage(hwnd,WM_NEXTDLGCTL,GetDlgItem(hWnd,IDC_OVERWRITE),.true.)
			case (IDC_APPEND)
				lret=SendMessage(hwnd,WM_NEXTDLGCTL,GetDlgItem(hWnd,IDC_APPEND),.true.)
			case (IDCANCEL)
				lret=SendMessage(hwnd,WM_NEXTDLGCTL,GetDlgItem(hWnd,IDCANCEL),.true.)
			end select
		end select
	case default
		OverwriteProc=0
	end select
	return
	end function OverwriteProc
Jugoslav_Dujic
Valued Contributor II
Add/remove BS_DEFPUSHBUTTON style using SetWindowLong(GWL_STYLE)?
Jugoslav_Dujic
...the reason I put the question mark at the end of my last post was because I knew that SetWindowLong(GWL_STYLE) does not always work. See here for a possible workaround.
Intel_C_Intel
Thanks for the suggestions.
BS_DEFPUSHBUTTON looked as if it might be what I wanted, but the documentation was in C and I wasn't sure where to make the call.
I ended up just replacing the SetFocus call in WM_SHOWWINDOW with a WM_NEXTDLGCTL call.
That mow seems to work.
David
	use dfwin
	logical*4	lret
    lparam = lparam
		OverwriteProc = 1
		return
		if (wParam) then
		endif
        OverwriteProc = 1
        return
		select case (iCtrl)
            OverwriteProc = 1
		case (IDC_APPEND)
            OverwriteProc = 1
		case (IDCANCEL)
            OverwriteProc = 1
		end select
	case default
		OverwriteProc=0
	end select
	return
