Using C Data Structures in Fortran
cbelwal
I want to build up a common data structure library which will be used in VB, Fotran and C apps. The choices are C and Fortran. If I build up a DLL with only Modules how can I use them in C. Alternately if I have a C DLL with struct definitions how do I use them in Fortran.
I tried to create a COM server in Fortran but apparently it does not expose the data structures inside a Module. Any help will be appreciated.
Chaitanya
