Using Generic Interfaces and Parameterized Types for selective early binding
Cristian_P_
I am using a parameterized type (called dispersion_type in the code) to select a function based on the value of a kind parameter of the type (namely, fkind). The different functions would have identical signatures if not for the additional argument of type dispersion_type(fkind).  With the additional argument, the functions can be collected under a  generic interface.  If the name of the generic interface is different from dispersion_type, the program works as desired.
If the name is the same, the code compiles and works with IFORT 15.0.1, but fails with IFORT 16.0.0, with the error
early_binding.f90(44): error #6593: The number of expressions in a structure constructor differs from the number of components of the derived type.   [DISPERSION_FORCE#2]
I think the code is correct though: in line 44, the second argument of dispersion_type(5., *) should call the structure constructor of dispersion_type, since there is no match available under the generic name.  The call to dispersion_type(5., *) itself should be to one of the overloaded versions available under the generic name.  It seems IFORT 16.0.0 decides there is no match and then tries to invoke the structure constructor again, which results in an error. Comments?
Module pairwise_potential
! Using a generic interface to bind procedures to parameterized types at compile times.
! The method works if the name of the type dispersion_force is DIFFERENT
! from the name of the generic interface, but it should work when the names
! are the same, too. That would be neater.
   Implicit None
   Type dispersion_force(fkind)
      Integer, Kind :: fkind = 2
   End Type dispersion_force
   Interface dispersion_force
      Module Procedure first_force
      Module Procedure second_force
      Module Procedure third_force
   End Interface dispersion_force
Contains
   Real Function first_force(rs, fkind)
      Real, Intent(In)                  :: rs
      Type(dispersion_force(1)), Intent(In) :: fkind
      first_force = 1.
   End Function first_force
   Real Function second_force(rs, fkind)
      Type(dispersion_force(2)), Intent(In) :: fkind
      second_force = 2.
   End Function second_force
   Real Function third_force(rs, fkind)
      Type(dispersion_force(3)), Intent(In) :: fkind
      third_force = 3.
   End Function third_force
   Subroutine verify_association
      Integer, Parameter :: fkind = 2
      Print *, 'The force kind is ', dispersion_force(5., dispersion_force(fkind)())
      !The above works with IFORT 15.0.1, but does not compile with IFORT 16.0.0
      !Furthermore, since the type dispersion_force has the default fkind=2, I expect
      !the following to also compile
      !Print*, 'The force kind is ', dispersion_force(5., dispersion_force)
      !Print*, 'The force kind is ', dispersion_force(5., dispersion_force(fkind))
   End Subroutine verify_association
End Module pairwise_potential
Program test
   Use pairwise_potential
   Call verify_association
End Program test
FortranFan
Looks like a bug in Intel Fortran with parameterized derived type (PDT) toward the facility starting with Fortran 2003 for a generic name in an interface being the same as derived type name.  The facility works with a derived type as shown below, but not with PDT.
module m
   implicit none
   private
   type, public :: dt
      integer :: k = 1
   end type dt
   interface dt
      module procedure k_dt
   end interface
   public :: verify
contains
   function k_dt( rin, t ) result(rout)
      real, intent(in)     :: rin
      type(dt), intent(in) :: t
      !.. function result
      real :: rout
      rout = rin + real( t%k, kind=kind(rout) )
   end function k_dt
   subroutine verify()
      print *, " In verify: ", dt( rin=1.0, t=dt(k=1) )
      return
   end subroutine verify
end module m
Compiling with Intel(R) Visual Fortran Compiler 16.0.1.146 [Intel(R) 64]...
m.f90
m - 0 error(s), 0 warning(s)
Notice the same error as in the original post for the case with PDT:
module m
   implicit none
   private
   type, public :: pdt(k)
      integer, kind :: k = 1
   end type pdt
   interface pdt
      module procedure k_pdt
   end interface
   public :: verify
contains
   function k_pdt( rin, t ) result(rout)
      type(pdt(k=1)), intent(in) :: t
      !.. function result
      real :: rout
   end function k_pdt
   subroutine verify()
      print *, " In verify: ", pdt( rin=1.0, t=pdt(k=1)() )
      return
end module m
m.f90
m.f90(32): error #6593: The number of expressions in a structure constructor differs from
the number of components of the derived type.   [PDT#1]
compilation aborted for m.f90 (code 1)
m - 2 error(s), 0 warning(s)
Steven_L_Intel1
Thanks, we'll take a look.
FortranFan
module m
   implicit none
   private
   type, public :: dt
      integer :: k = 1
   end type dt
   interface dt
   end interface
   public :: verify
contains
      !.. function result
      real :: rout
   end function k_dt
   subroutine verify()
      return
end module m
m.f90
module m
   implicit none
   private
   end type pdt
   interface pdt
   end interface
   public :: verify
contains
      !.. function result
      real :: rout
   end function k_pdt
   subroutine verify()
      return
end module m
m.f90
Cristian_P_
Thanks for the concise example, FortranFan.  I think your example settles it as a bug.
PDTs seem an important feature of Fortran.  Maybe Fortran will also adopt named enumerations (most of the syntax is there anyway, having been introduced for C interoperability).  I could use an easy way of creating a restricted set of integer parameters (restricted to "valid type parameters").
Steven_L_Intel1
Thanks from me as well.  Escalated as issue DPD200380357.
Steven_L_Intel1
Fixed for a major release later this year.
Cristian_P_
Thanks, Steve.
