29434 Discussions
Using Intel Array Visualizer in debug mode
pastorix
I am trying to use the Intel Array Visualizer to examine some arrays while debugging a program in Visual Studio Premier Partner Edition & Intel Visual Fortran 10.1 under XP 64.
I downloaded and installed the Array Visualizer following the instructions. The context menu I obtain when I right click on the array name, though, has the "View Array" item disabled. The Array Visualizer can be opened as a standalone application, but this is not as helpful as calling it from inside the debugger, as it was possible with the Compaq AV in Compaq VF.
Am I missing something in the installation process? Any suggestion?
