29653 Discussions
Using Interface Statements to call C from Fortran
mhovers
Here is a simple test program of 3 files (below) when I try to compile and link in Visual Fortran (VS) I get:
1>------ Build started: Project: test, Configuration: Debug Win32 ------
1>Compiling with Intel Fortran 11.0.061 [IA-32]...
1>test3.f90
1>Linking...
1>test3.obj : error LNK2019: unresolved external symbol _c_code referenced in function _MAIN__
1>Debug\\test.exe : fatal error LNK1120: 1 unresolved externals
1>
1>Build log written to "file://C:\\Users\\hovg\\test\\Debug\\BuildLog.htm"
1>test - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
What am I missing??
FILE 1:
program test
use int_mod
real*4 a(50)
integer*4 n
call c_code(n,a)
write(*,*) (a(i),i=1,n)
stop
end
FILE 2:
module int_mod
interface
subroutine c_code(nn,a)
!DEC$ ATTRIBUTES C, ALIAS:'_c_code' :: c_code
!DEC$ ATTRIBUTES REFERENCE :: nn
!DEC$ ATTRIBUTES REFERENCE :: a
integer*4 nn
real*4, dimension (*) :: a
end subroutine c_code
end interface
end module
FILE 3:
void c_code(n,a)
int n;
float *a;
int i;
n =10;
for (i=0;i
a = (float) i;
return;
IanH
Are you linking in the object file produced from compilation of the c file? The build log would help us diagnose. Within Visual Studio you probably need to make the Fortran project depend on the C project. Details depend on the version of Visual Studio, but right click on the fortran project and look for a Project dependencies item or similar in the resulting menu.
A better (compliant with Fortran standards and therefore more portable and robust) way of writing the interface is:
[fortran]module int_mod
IMPLICIT NONE
interface subroutine c_code(nn,a) BIND(C, NAME='c_code') USE, INTRINSIC :: ISO_C_BINDING, ONLY: C_INT, C_FLOAT IMPLICIT NONE INTEGER(C_INT), INTENT(OUT) :: nn REAL(C_FLOAT), INTENT(OUT) :: a(*) end subroutine c_code end interface end module int_mod[/fortran]
Note the use of the standard INTEGER(xx) style declarations, rather than the INTEGER*xx form, the latter is a language extension. You could apply similar changes to your main program too. (If you see a red coloured REAL in the code above then that is just due to a problem with the forum software - please ignore it)
More importantly, the first argument in your c function as presented above is being taken by value, not by reference. The form of the declarations for the function arguments are also a relic of a bygone era. Consider:
[cpp]void c_code(int *n, float *a)
   int i;
   *n = 10;
   for (i = 0; i < *n; i ++) {
      a = (float) i;
   return;
[/cpp]
