Using MODULE source files
magliola
In a single source file (source.for) I have the following structure. (I use one file because this is how I used to load the hopper with cards.)
module one
integer a, b, c, d
end module one
module two
integer e, f, g, h
end module two
program main
use one
use two
end
subroutine mysub
use one
use two
end
In Developer Studio how do I create MOD source files and where do they go? I see three locations - SOURCE files, HEADER files, RESOURCE files.
When I press Ctrl+N I have the choice to create the following files: Binary, Bitmap, ..., Fortran Fixed Format, Fortran Free Format, .... I don't see a choice to create a MOD file.
Any help will be appreciated.
David_V_3
*.mod files are intermediate files created by the compiler. As I understand it a *.mod file is created for each module found in a source file. That is, in your example one.mod and two.mod will be created when you compile your single source file. You can control the location of the *.mod files with the /module: compiler switch.
magliola
OK. I had it all wrong. I see what is going on now. The *.mod files were in the DEBUG subdirectory of the project along with the *.obj file.
I could put the source code for the modules in a *.for file and add that file to the project.
Thank you for your help.
