Using RUNQQ
waterresourcesengine
I'm trying to utilize the RUNQQ procedure on a 64 bit Intel machine.
My code compiles fine but RUNQQ will return an error code of 2 using GETLASTERRORQQ; which appears to be related to ERR$NOENT (as found in IFPORT.F90 code)
The result from RUNQQ itself is -1
What my be causing this?  I've tried doing several things using RUNQQ with no success.
I've been able to get SYSTEM and SYSTEMQQ to work OK on my machine but not RUNQQ
Thanks for advice.
andrew_4619
I would guess it is the path the the program you are trying to run. Give the program nane including the full path in 'quotes'  perhaps?
By placing the procedure I want to call using RUNQQ into the same directory as my procedure containing the RUNQQ call, it works.
I had assumed that as long as the procedure being called by RUNQQ was in my defined PATH it would be accessed but apparently not......
And including the entire path in the RUNQQ call would accomplish this also.
andrew_4619
In windows the 'local' path is what windows decides....  I normally call get_command_argument to get the loacation of the exe that is running and then append the program to run on the end of this path...
[fortran]iarg=0 !get cmd line for locn of .exe, used for file locns
call get_command_argument (iarg, garg, ilen, istat)
if(istat.eq.0) then
ncdpth=index(garg,'\',.true.)
gcdpth=garg(1:ncdpth)
else
ncdpth=0
endif[/fortran]
