Using a Factory Pattern
stutzbach
I have a problem with a code using a factory pattern. The compiler reports a error i do not know how to fix.
I using the Intel Visual Fortran Composer XE 2011 12.0.3470.2010.
Error: error #8314: If the rightmost part-name is of abstract type, data-ref shall be polymorphic [CREATEWORKINGMODEL] in main.f90 line 15.
Perhaps someone knows how to fix this error?
Greetings Moritz
PROGRAM main
USE workingmodel_factory
IMPLICIT NONE
CHARACTER(len=20) :: string
TYPE(cfactory) :: factory
CLASS(workingmodel), POINTER :: pworkingmodel => null()
string = 'H'
CALL factory%init(string)
pworkingmodel => factory%createworkingmodel()
CALL pworkingmodel%description()
END PROGRAM main
MODULE workingmodel_factory
USE tcH
IMPLICIT NONE
TYPE cfactory
PRIVATE
CHARACTER(len=20) :: chfactory
CONTAINS
PROCEDURE :: init
PROCEDURE :: createworkingmodel
END TYPE cfactory
CONTAINS
SUBROUTINE init(this, string)
CLASS(cfactory), INTENT(INOUT) :: this
CHARACTER(len=*), INTENT(IN) :: string
this%chfactory = trim(string)
this%pworkingmodel => null()
END SUBROUTINE init
FUNCTION createworkingmodel(this) RESULT(ptr)
CLASS(cfactory) :: this
CLASS(workingmodel), POINTER :: ptr
IF (this%chfactory == 'H') THEN
IF (ASSOCIATED(this%pworkingmodel)) DEALLOCATE(this%pworkingmodel)
ALLOCATE(tH :: this%pworkingmodel)
ptr => this%pworkingmodel
ELSEIF (this%chfactory == 'Z') THEN
ALLOCATE(tZ :: this%pworkingmodel)
END IF
END FUNCTION createworkingmodel
END MODULE workingmodel_factory
MODULE tcH
USE extensions
IMPLICIT NONE
TYPE, EXTENDS(workingmodel) :: tH
CONTAINS
PROCEDURE, PASS(this) :: description => h_desc
END TYPE tH
CONTAINS
SUBROUTINE h_desc(this)
CLASS(tH), INTENT(IN) :: this
WRITE(*,*) 'H'
END SUBROUTINE h_desc
END MODULE tcH
MODULE extensions
IMPLICIT NONE
TYPE, ABSTRACT, PUBLIC :: workingmodel
CONTAINS
PROCEDURE(generic_desc),PUBLIC, PASS(this), DEFERRED :: description
END TYPE workingmodel
ABSTRACT INTERFACE
SUBROUTINE generic_desc(this)
IMPORT :: workingmodel
CLASS(workingmodel), INTENT(IN) :: this
END SUBROUTINE generic_desc
END INTERFACE
TYPE, EXTENDS(workingmodel) :: tZ
CONTAINS
PROCEDURE, PASS(this) :: description => z_desc
END TYPE tZ
CONTAINS
SUBROUTINE z_desc(this)
CLASS(tZ), INTENT(IN) :: this
WRITE(*,*) 'Z'
END SUBROUTINE z_desc
END MODULE extensions
IanH
I think it is a compiler bug. See this post.
A work around is to make your factory procedure a subroutine rather than a function, i.e:
[fortran]  SUBROUTINE createworkingmodel(this, ptr)
    CLASS(workingmodel), INTENT(OUT), POINTER :: ptr
    ...[/fortran]
Otherwise, if you get => and = mixed up, all sorts of wonderful, mysterious, but ultimately painful things will start happening in your program.
As an aside, if I was writing to the factory pattern I would have a abstract parent type for the factory as well, and then extensions of that type to actually create the objects, rather than a big switch statement. Alternatively, the string that designates the type of object to be created would be an argument to the createworkingmodel routine.
