I'ld like to ask why it isn't possible to use a base class for passing the object:
module greet_mod
type, abstract :: GREETER
character(100) :: name
contains
procedure(greet_fun), deferred :: greet
end type GREETER
abstract interface
subroutine greet_fun(this)
import :: GREETER
class(GREETER), intent(in) :: this
end subroutine greet_fun
end interface
type, extends(GREETER) :: ENGLISH_GREETER
contains
procedure greet => en_greet
end type ENGLISH_GREETER
contains
subroutine en_greet(this)
class(GREETER), intent(in) :: this !won't work
!class(ENGLISH_GREETER), intent(in), this !works
write(*,*) 'Hi ',trim(adjustl(this%name))
end subroutine en_greet
end module greet_mod
program test_greeter
use greet_mod
class(GREETER), allocatable :: gtr
allocate(ENGLISH_GREETER::gtr)
gtr%name='F03'
call gtr%greet()
end program test_greeter
error #8262: For a type-bound procedure that has the PASS binding attribute, the first dummy argument must have the same declared type as the type being defined. [THIS] subroutine en_greet(this) ----------------------^
Is this normal behavior?
Thanks in advance!
链接已复制
1 回复
Yes, this is what the standard specifies.
C456 The passed-object dummy argument shall be a scalar, nonpointer, nonallocatable dummy data object with the same declared type as the type being defined; all of its length type parameters shall be assumed; it shall be polymorphic (4.3.1.3) if and only if the type being defined is extensible (4.5.7). It shall not have the VALUE attribute.
