VB BOOLEAN ARRAY TO CVF DLL
philbrierley
I am trying to pass a boolean array, among other things,from vb to a cvf dll.
Ifthe (fist element of)boolean array is at the end of the parameter list then VB will notrun as it basically says the arguments don't match.If I pass it as the first argument then it runs but the arrays are not received correctly.
Is there a second parameter that needs to be passed with boolean arrays?
(similar to fixed length strings where the length of the string needs to be passed)
In cfv I am receiving the boolean as a logical (kind=2).
Any pointers would be appreciated.
philbrierley
Ignore the previous query !!!!
