VIsual studio crashes
antony
Since installing the version 15 update, visual studio often crashes. At least two ways:
* With lots of files open in solution/projects, right click file tab and select "close all but this", crashes immediately.
* When changing source code branch using external git program, when switching back to visual studio it ask whether to reload files - on confirming it crashes.
Both were fine previously.
Microsoft Visual Studio Professional 2013
Version 12.0.30723.00 Update 3
Microsoft .NET Framework
Version 4.5.50938
Intel® Parallel Studio XE 2015 Composer Edition for Fortran Windows* Package ID: w_fcompxe_2015.0.108
Intel® Parallel Studio XE 2015 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2013, Version 15.0.0107.12, Copyright © 2002-2014 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
(I tried submitting an issue on the business portal but get error about The requested URL was rejected. Please consult with your administrator. Your support ID is: 1340398033970549014)
