29487 Discussions
VS 2010 How to show compiler options during build?
chauvjo
Does Visual Studio 2010 have an options to show the compiler options for each source file during the build process? The default configuration only shows the source file name in the output window during a build.
IanH
Do a rebuild and then have a look at the build log for the project (linked to in the output window).
chauvjo
Does that mean there is no options to show the build options in the output window during the actual build?
Thanks...
IanH
Not that I am aware of. Is there a particular reason that you need to see the stuff in the output window?
