VS 2022 how to add intel fortran
Thanh_Nguyen_R
Hello
I just installed VS 2022 and Intel Fortran OneAPI, it does not show  intel fortran from the " all laguages" drop down menu when creating new project
Have been trying do some searching but it seems not helpful hint found. Any one has the same issue pls share your tip
Thanh
DavidWhite
Valued Contributor II
Hi Thanh,
noticed that you got no replies to your request.
If VS doens't recognize the Intel Fortran packages, the common advice is to rerun the Intel installer and make sure that the integration with VS is completed.
David
IanH
...and make sure that you have the "Desktop development with C++" Visual Studio component installed.
