VS Integration XE2016 / Submodule
andrew_4619
compiling with submodules we not get .mod and .smod files. When you clean to do a fresh build (clean) the .smod files are not deleted and I am guessing that they should be. Perhaps it is not important.......
andrew_4619
Actually it is not that simple, it doesn't delete ALL .smod files or the behavior as changed since I made some changes to the project. It my be connected to the bugs in dependency checking when using submodules.  I will see if I notice a pattern.
Kevin_D_Intel
Thank you for this note. I will look at some of the test cases from the earlier submodule issues and reply again when I know more.
