29386 Discussions
VS2008 & IVF stopped working: cannot compile anymore
joerg_kuthe
Hello:
For some unknown reason IVF doesn't compile any of the Fortran files in my IVF projects anymore. When I left my desk on Friday everything was working fine. I shut down my Windows 7 PC (Win7 Ultimate) and it might be that Windows installed some updates. And today I found myself stuck and not being able to use the compiler in VS2008.
If I try to compile or to re-build an IVF console project (both 32 & 64-bit), nothing happens, IFORT doesn't start and not a single error message is displayed.
If I try toto re-build an IVF project containing a resource file (.rc), again, IFORT doesn't start, but I can cause the resource compiler to launch and when linking I get the error message:
1>Linking...
1>LINK : warning LNK4068: /MACHINE not specified; defaulting to X86
1>LINK : error LNK2001: unresolved external symbol _mainCRTStartup
1>Matfor3D.exe : fatal error LNK1120: 1 unresolved externals
I definitely haven't changed this project and it definitely generated an .exe without error.
I have installed both IVF v11.1.07 and v12.1.258 (32-bit and 64-bit variants) in VS2008 (Std. Ed.). V12.1 is also integrated in VS2010 (Prof. Ed.). My VS2010 solutions and .vfproj files still work. So far, I could use both VS editions on this PC concurrently without any problems.
I have checked the path settings (in Options | Intel Visual Fortran | Compilers), but did not see anything suspicious:
Executables directories list:
$(IFortInstallDir)bin\\ia32
$(CommonProgramFiles)\\Intel\\Shared Files\\Ia32\\Bin
$(VSInstallDir)Common7\\IDE
$(VCInstallDir)BIN
$(VSInstallDir)Common7\\Tools
$(VSInstallDir)Common7\\Tools\\bin
$(FrameworkDir)$(FrameworkVersion)
$(WindowsSdkDir)bin
$(PATH)
Libraries directories list:
$(IFortInstallDir)lib\\ia32
$(IFortInstallDir)mkl\\ia32\\lib
$(VCInstallDir)atlmfc\\lib
$(VCInstallDir)lib
$(VCInstallDir)PlatformSDK\\lib
$(VCInstallDir)PlatformSDK\\lib\\x86
$(WindowsSdkDir)lib
E:\\Program Files (x86)\\AnCAD\\MATFOR4\\lib\\IF9
E:\\Program Files (x86)\\gino\\v7.5c
I can start IFORT 11.1 from the console (via Start | Intel ...|Fortran Build environment for ....)
I have not got a clue what happened to my machine. Can anyone help me to get me back to work? Thank you.
Kind regards,
Jrg Kuthe
See here, Step 1, fourth bullet. That usually works.
joerg_kuthe
Thanks a lot Steve. That saved my day. I have no idea why these file endings disappeared.
Jrg
Me neither. I have seen customers report this problem after installing a Fortran update, though we have never been able to pin it down. You say this was after doing some non-Fortran updates?
