29487 Discussions
VS2022 Fortran OpenMP number of processes always one
Scorp
I have a large project I'm attempting to partially parallelize.  I have the following settings on the project property pages:
debug: environment: OMP_NUM_THREADS=8
fortran: language: process OpenMP directives: Generate Parallel Code (/Qopenmp)
fortran: runtime library: debug multithreaded
The below subroutine should print the thread id from 0 to 5, but instead it prints. Why?
F  6
# threads:  1
hello from thread:  0
subroutine clauses
USE OMP_LIB
implicit none
call omp_set_num_threads(6)
PRINT *, OMP_IN_PARALLEL(), OMP_GET_MAX_THREADS()
!$OMP PARALLEL
print *, "# threads:", OMP_GET_NUM_THREADS()
print *, 'hello from thread:', OMP_GET_THREAD_NUM()
!$OMP END PARALLEL
end subroutine clauses
Scorp
If you have a solution with multiple projects, you have enable the same project properties as those for the startup. I only had it only for the startup and it didn't work for those files in another project.
All fixed now.
jimdempseyatthecove
Scorp,
Check to see if you are building with the OpenMP stubs library.
Jim Dempsey
Scorp
Jim,
I am not. Language -> Process OpenMP Directives, which I already set to Generate Parallel Code (/Qopenmp). Setting it to Generate Sequential Code (/Qopenmp-stubs) results in:
F  1
# threads:  1
Scorp
All fixed now.
