29560 Discussions
VS2022 community, latest intel OneApi-The Intel(R) Librarian xilink.exe could not be found
Bulent
A few days ago I installed VS2022 community edition and intel fortran compiler (it was before w_BaseKit_p_2022.1.2.154) I belive it was 2022.0 xxx. and w_HPCKit_p_2022.1.0.93 on my Windows 10 pro. It worked like a charm. I was able to compile.
I updated my OS to Windows 11 yesterday. And when I compiled FORTRAN code, I noticed that ALL the compile and link option on VS22 was different. Like BOOL_TRUE instead of True. fixedLenght72 instead of 72.
I uninstalled all, tried all installation combinations, including rolling back to Windows 10 and installing it again. The above problem was resolved but could not compile this time b/c (xilink.exe) could not be found.
Still, the same problem " The Intel(R) Librarian (xilink.exe) could not be found."
Please help.
PS. Currently I have Windows 11 installed since it reinstalls itself automatically even if you rollback.
Bulent
I downloaded and installed previous version of basekit w_BaseKit_p_2022.1.0.116. It worked like a charm on Windows 11.
Problem solved.
Steve_Lionel
Did you try uninstalling and reinstalling the oneAPI HPC Toolkit? I upgraded from Windows 10 to Windows 11 the other day and haven't seen an issue with building Fortran code.
Bulent
Steve,
Yes, several times. The latest try included uninstalling and deleting all intel components,
then  install clean VS22, install oneAPI base and oneAPI HPC Toolkit. Same issue.
Steve_Lionel
Do you also have Microsoft Visual Studio's option for "C++ Desktop Applications" configured? Installing Microsoft Visual Studio* for Use with Intel® Compilers
xilink.exe should be in C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\bin\intel64 .
In VS, select Tools > Options > Intel Compilers and Libraries > IFORT Intel Fortran Classic > Compilers. In the Win32 or x64 tab, clicking on Executables should show $(IFortInstallDir)bin\Intel64 as one of the lines. If not, click Reset.
Bulent
Problem solved.
Ludwig_
Hi. I just met the same problem, but I couldn't find where to download the previous version of base toolkit w_BaseKit_p_2022.1.0.116.  So could you leave the download address? Thanks a lot.
Bulent
Login to you  Intel account and download the latest version.  It will give you option to access and  download previous versions, when you do so.There is webpage that explains how to do so.  Let me know the outcome.
Ludwig_
I found the right website and the previous version of basekit works perfectly.
https://registrationcenter.intel.com/en/products/download/4188/
MarcioBezerra
Hello.
It looks like the link is not working anymore. Does anybody know if there is a workaround?
Much appreciated.
Feng__Jesse
New Contributor II
The link works for me but for reference:
After logging into your account. Go to Dashboard -> Content -> See all content -> Software products -> Select your product -> Download options
Then everything should be self-explanatory from here.
