29427 Discussions
VS2022 integration: "An error occurred XXXX while attempting to open YYYY.for"
lxander
Anyone else seeing something like this when reopening a VS2020 solution ...
If I close the tab and reopen it, the file comes up fine.  Is there something in the integration settings I need to change?  (I've already done a fresh install of the Intel® oneAPI Base Toolkit.)
IanH
Known issue - there have been multiple reports here.  Occurs if you have files open when you close the project.  Close the tab for the file, reopen the file, continue working, meanwhile wait for a fix from Intel.
