29649 Discussions
VS2022 mouse hover doesn't the variable value
Shuang_Geo
Hello, everyone! I just installed the VS 2022 Community and the oneAPI base toolkit,  oneAPI HPC Toolkit. But when I use this to debug my fortran program and set a breakpoint, this program stops at the breakpoint, but I can't see the value of these variables. Anyone has ideas about that?
Alessandro_D_
I observed exactly the same problem as you describe. To see the value of a variable you can type the name in the immediate window and press return. However, it would be useful to have the mouse hovering feature available.
Devorah_H_Intel
What is the version of VS installed?
I tested with supported Version 17.1 and hovering works.
Alessandro_D_
I have VS 2022 Community and the oneAPI base toolkit,  oneAPI HPC Toolkit, installed in March 2022. Everything works OK but not the mouse feature
NeilMc
We ran into this problem - we managed to fix it by updating to the latest version of VS2022 - which was 17.5.5
bharathswami
Hi
If it helps,
I ran into the same issue when debugging in Visual Studio on a Remote System. For that, under "Debug"->"Options...". Load Debug Symbols in External Process (Native Only) needs to be unchecked.
Accept and Upvote my answer if it helps.
Thanks and Regards
Bharath
jackosullivan2
Worked like a charm!  Wish I'd found your answer several days ago!
Thank you, Bharath.
Using Intel Fortran Compiler 2023.2 in VS2022 Version 17.7.6
hkvzjal
I just observed the same problem with MVS2022 (17.7.6)  and had to manually change the options using the solution proposed by @bharathswami to get the value of variables when hovering over.
Devorah_H_Intel
2024 Intel Fortran Compiler release will have a better support for later versions of VS 17.7 and this is one of the issues that is fixed in that  version.
