Valid code rejected?
jahern
This code was rejected byifort11.1 20090511, froml_cprof_p_11.1.038 on Fedora 11 x86_64.
[plain]PROGRAM invalid
   IMPLICIT NONE
   TYPE, ABSTRACT :: foo
      INTEGER :: i
   END TYPE foo
   TYPE, EXTENDS(foo) :: bar
      INTEGER :: j
   END TYPE bar
   TYPE wrapper
      CLASS(foo), ALLOCATABLE :: comp
   END TYPE wrapper
   TYPE(wrapper) :: obj
   ALLOCATE(bar :: obj%comp)
END PROGRAM invalid [/plain]
I receive the following error message:
[plain]bug.f90(13): error #8307: If the rightmost part-name is of
abstract type, data-ref shall be polymorphic   [COMP]
compilation aborted for bug.f90 (code 1)[/plain]
However, I believe this code to be valid: data-ref refers to %comp, and it is polymorphic. See:
If I alter the code to have obj polymorphic and allocate it, as in the follow-up in my previous thread, I get:
[plain]0_12032
: catastrophic error: **Internal compiler error: internal abort** Please report[/plain]
[plain]this error along with the circumstances in which it occurred in a Software Probl[/plain]
[plain]em Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for bug.f90 (code 3)[/plain]
Jared
jahern
Ha. Okay, I messed up the formatting there... oops. Maybe I shouldn't have bothered to put the error msgs into code snibbits.
Kirill_Mavrodiev__In
Hi All,
There are submitted Defects reports regardingInternal Compiler Error(ICE) and for error #8307. (
DPD200137426 and DPD200137377)
Kirill.
jahern
Hi All,
Kirill.
Ah, thanks! I had forgotten to check around for them.
