Variable Format Expressions IVF 8
jancer
Taking my first steps in CVF 6.1 to IVF 8 conversion I encountered an unexpected problem with variable format expressions:
In a subroutine I have the following two lines:
WRITE(21,61) TRIM(chTempDir)
61 FORMAT('d ',aLEN_TRIM(chTempDir))
(please replace the by angle brackets. I can't use them here because I "don't have permission to post HTML".)
where chTempDir is of type CHARACTER(LEN=200) and made available via a use statement. Its value is set in the program unit that calls the subroutine in question.
My variable format expression used to work fine in CVF6.1 but now the value of chTempDir is deleted upon entry into the subroutine (as can be seen by adding a WRITE(*,*) chTempDir line at the top of my subroutine).
When I replace my variable format by a200, everything works fine again.
What's my mistake?
Thank,
Jan Cermak
Jugoslav_Dujic
Valued Contributor II
Sounds like a compiler bug, and you should report it to Premier...
...however, you don't seem to be aware of a simpler, standard & portable way: plain A edit descriptor (without length specifier):
WRITE(21,"('d ', a)") TRIM(chTempDir)
which means exactly
WRITE(21,"('d ', a[LEN(Associated_IOitem)])") TRIM(chTempDir)
i.e.
WRITE(21,"('d ', a[LEN(TRIM(chTempDir))])") TRIM(chTempDir)
Jugoslav
Message Edited by JugoslavDujic on 03-22-2004 08:36 AM
One would need to see the full example, and the best place to do that is to send to Intel Premier Support. I know that early versions of the compiler had problems with "uplevel references".
Do try the latest compiler before reporting the problem.
