29341 Discussions
Variable Format Expressions Not Allowed in Fortran 2018
SunMesa
When checks for Fortran 2018 compatibility are turned on, I see that variable format expressions, e.g., statements like Write(2,'(<NMassBins>F10.3)')NDat, are no longer allowed. I personally thought this was a pretty handy feature, but in any case, what is the suggested alternative to get the same effect? Thanks for any info!
Steve_Lionel
The "unlimited repeat count" feature from F2008 is often a good substiute. If nothing else, you can write a format into a character variable and use the variable as your format.
Steve_Lionel
SunMesa
Thanks Steve, the unlimited repeat count worked. I replaced
with
Write(2,'(*(F10.3))')NDat
and the compiler was happy. I thought I'd try your second option (construct a format on the fly), and came up with this:
Integer :: NMassBins
Real, Allocatable :: NDat(:)
Character(12) :: FMT
NMassBins = [Some calculated integer, say N]
Allocate(NDat(N))
NDat = [Some calculated array]
Write(FMT,'(a2,I2,a8)') "'(", NMassBins, "(F10.3)'"
Write(2,FMT)NDat
The compiler was similarly o.k.  with that, although it's rather cumbersome, and seems problematic if I didn't know beforehand that NMassBins was no bigger than 99.
Any idea why variable format expressions are now frowned upon? They would seem to be a much cleaner method than either of the above alternatives.
SunMesa
The code snippet above, although it compiles, is incorrect. It should be:
Character(11) :: FMT
Allocate(NDat(N))
Write(FMT,'(a1,I2,a8)') '(', NMassBins, '(F10.3))'
Write(2,FMT)NDat
This code compiles and executes correctly, and produces identical results to the 'unlimited repeat' method above. Same question though, why is the (to me, anyway) more explicit and more readable/intuitive method of variable format expression now out of favor? In any case, I've flagged this as solved, thanks Steve!
GVautier
New Contributor III
Instead of
use
Write(FMT,'(a2,I0,a8)') "'(", NMassBins, "(F10.3)'"
to be independent of NMassBins
SunMesa
GVautier,
That's a good point, I0 formatting would produce the minimum required size when writing to the variable FMT, but then the question arises, how do you declare the size of the character variable FMT? One solution is to just make it some large value and use TRIM(FMT) in the write statement. I've tried this and it works... not very elegant, but effective.
FortranFan
Not sure how any group of people can even define elegance, let alone hope to succeed in bringing it consistently into a language, especially one like Fortran with its long legacy.
For the kind of situations shown by OP in this thread, current standard Fortran allows the following that includes both a generic descriptor and an unlimited repeat count.  Many readers may find it good enough for their needs.
   real :: Ndat(3)
   character(len=*), parameter :: fmtg6 = "(*(g0.6,1x))"
   call random_number( Ndat )
   print fmtg6, "Ndat: ", Ndat
end
Output can be:
Ndat:  .392087E-06 .254804E-01 .352516
Steve_Lionel
Variable Format Expressions (VFEs) were a DEC invention from the PDP-11 era. They were carried forward into VAX FORTRAN, DEC Fortran and then Intel Fortran. Other vendors cursed us as VFEs are un-Fortran-like and difficult to implement properly, but customers liked them and so some vendors broke down and put them in. In most cases where VFEs were used, unlimited repeat works well, but one can construct more complex cases where it doesn't. For that there's run-time formats, which ARE standard.
andrew_4619
"Any idea why variable format expressions are now frowned upon? "
That has never been part of standard Fortran it is a vendor extension. Intel chose to support it but if you choose also standards checking you will get errors/warnings. The extension is not needed anyway as other standard confirming methods can be used as illustrated in this thread.
