29398 Discussions
Variable to know Linux or Windows
Zorrilla__David
Is there a variable in fortran that say if the program is running in linux or windows or mac?
TimP
Quoting - zorro68
There is no portable way. At compile time, if you invoke pre-processing, most systems have automatic defines which you could test, e.g. by #if defined .....
For example, if you run ifort -# somelittlefile.F, on linux, you should see which text strings are pre-defined for that system. On Windows ifort, a /Qfpp option will be required, as you can't invoke pre-processing by .F or .F90 suffix.
See the section about Predefined Preprocessor Symbols in the ifort help, where predefines including __linux __APPLE__ _WIN32 are discussed.
At run time, you could do something like
ierrorcode = system("uname -ps > uname.txt") and check what just got written to that file, as well as handling any error returned.
jimdempseyatthecove
Quoting - zorro68
When you run on Windows, there are specificly namedenvironment variables used. Try examining
[cpp]OS=Windows_NT
SystemRoot=C:WINDOWS
windir=C:WINDOWS
[/cpp]
Jim Dempsey
Steven_L_Intel1
Since you cannot run the same executable on Linux and Windows, you can use the preprocessor symbols to "detect" the OS.
