29359 Discussions
Variables whose names start with "CLASS" cause compiler errors
Chris_Payne
Here is the source for a test case
program x
integer*4 classic_bug
classic_bug = 4
write (6,*) classic_bug
end
Using command line ifort -f77rtl -save -vms -align norecords -warn noalign -extend-source x.for
Version 11.1.056 on Linux, returns the following compiler errors
x.for(4): error #5082: Syntax error, found IDENTIFIER 'IC_BUG' when expecting one of: ( % : . = =>
classic_bug = 4
x.for(4): error #6535: This variable or component must be of a derived or structure type [CLASS]
classic_bug = 4
x.for(4): error #6460: This is not a field name that is defined in the encompassing structure. [IC_BUG]
classic_bug = 4
compilation aborted for x.for (code 1)
TimP
The bug was discussed here
http://software.intel.com/en-us/forums/showthread.php?t=68600
with the original poster's reference to "Fortran 77" referring to the fact that the bug was exhibited only for fixed source form. It is supposed to be present only in that one version, and corrected in 11.1.059.
TimP
