29564 Discussions
Vectorization and segmentation fault
Matthieu_B_
I have a problem with an old software that used to work with ifort 11 and does not anymore with recent versions.
This software is written in fortan 77 and uses an old trick to manage its memory. This trick leads to the arrays out of their bounds so don’t be shocked!
The idea is, at the beginning of the execution to allocate a big array with a C malloc and to calculate the distance from this array and a reference array (called refarr in the following). To get data with the good type in the allocated array, an equivalence statement is used.
In this software,  a loop always return a segmentation fault when it is vectorized and I don’t get why. Here is a simplified source code :
[fortran]
      subroutine mysub(datpos,n)
c     datpos = data position in the allocated array
      implicit none
      integer*8 DIST ! distance of the reference array to the allocated array
      integer   datpos,n
      integer   refarr
      integer*8 adress_arr(1)
      integer   anint,i,j,jj(n)
      COMMON/MYCOM/DIST,refarr(2)
c      with this statement, refarr, adress_arr are at the same adress
      equivalence (refarr(1),adress_arr(1))
c    some code her
      anint = 0
      do i=4,n !or anything else here
        jj(i)=refarr(adress_arr(DIST+datpos)+1+i)
        if(refarr(adress_arr(DIST+jj(i))+3).EQ.4)THEN
          anint = 1
        ENDIF
      enddo
c    more code her
      return
      end
[/fortran]
With ifort11, this loop was not vectorized and it worked. I obviously found the solution to use the NOVECTOR directive but it does not explain the problem. I found another solution : if I declare a jj array and change the loop this way, the software works (I also needed to use the VECTOR ALWAYS directive because the optimizer says that the vectorization of the modified loop seem unefficient) :
[fortran]
          anint = 1
        ENDIF
      enddo
[/fortran]
Does anyone have an idea of what is the problem ?
Martyn_C_Intel
I didn't imagine it; I did test an early 15.0 compiler and the fix did work. However, a subsequent fix to a different issue caused a regression in this one, and this wasn't detected until after the product release, due to a technical problem (relating to the memory footprint). A new fix for both issues is in progress. It will not be in the first update to the 15.0 compiler, which will be posted shortly, but it should be in the second update sometime in the new year.
Apologies for the thrash on this.
Martyn_C_Intel
Just confirming that this issue is indeed fixed in update 2 to the 15.0 compiler, 15.0.2.164, which is available via the Intel Registration Center.
