29487 Discussions
Vectorization report - where is it? and why such long lines in build log?
anthonyrichards
New Contributor III
IVF 11.1.067 VS2005
I compile the following code with options /c /QxSSSE3 /Qvec-report:3 /Qvc8 (among others) but get no vectorization report messages (even negative ones) in the build log (attached). Why is this?
program testassembly
implicit none
integer(4),parameter::N=10000
REAL(8) A(N), B(N), TOTAL
INTEGER(4) i,j
do i=1,N
A(I)=1.0D+00
B(I)=2.0D+00
enddo
call DOTPROD(A,B,N,TOTAL)
end program testassembly
subroutine DOTPROD(A,B,N,TOTAL)
integer(4) N,I
REAL(8) a(N),B(N),TOTAL,CONST
CONST=0.0D+00
do i=1,N
CONST=CONST+A(I)*B(I)
end do
TOTAL=CONST
return
end subroutine DOTPROD
P.S. Why must the build log display such long lines which makes selection of sections in the build.log window so difficult?
TimP
$ ifort -Qvec-report3 -Qip- ar.f
Intel Visual Fortran Intel 64 Compiler XE for applications running on Inte
l 64, Version 12.0.1.127 Build 20101116
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
C:\src\net\ar.f(9) (col. 11
): remark: LOOP WAS VECTORIZED.
C:\src\net\ar.f(21) (col. 1
1): remark: LOOP WAS VECTORIZED.
Strange things happen with in-lining of examples where dead code is eliminated, and when extra characters such as your : go in the command line options.
Yes, there's no attention to text line formatting.
anthonyrichards
New Contributor III
Thanks, but I always use the VS2005 IDE, which gives me loads of command line options, compared to your 2 options (Qip and Qvec-report). How can I trim down my IDE command line?
With my present set of options (see build log) I get
Source2.f90(12): (col. 10) remark: routine skipped: no vectorization candidates.
Source2.f90(29): (col. 13) remark: routine skipped: no vectorization candidates.
The source code is as posted above. Note, I asked for the assembler code listing.
So I then decided to try command line compilation (for the first time!) using your options.
After opening a Command window, navigating to the project folder and running ifortvars.bat ia32 vs2005, I ran your commands:
ifort -Qip -Qvec-report3 source2.f90
and got
source2.f90(20): (col. 2) remark: LOOP WAS VECTORIZED.
So I only got one loop vectorised compared to your two. I don't quite understand the messages: why use 'column' reference? I understand (20) implies line 20, but where is line 1 and do blank lines count?
The lines are exactly what you see in Visual Studio if you have line numbers turned on. It is a simple count of lines in the source file, starting with the first one. Blank lines count.
TimP
I set -Qip- in order to avoid the dead code elimination affecting source lines 29ff. There is a Visual Studio option for that; it defaults to -Qip.
John_Campbell
New Contributor II
Is it possible to generate a code listing (/lis) with the vectorization report directed to the listing, so we do not need to interpred the line and column number (?) or loop level ?
