29386 Discussions
Versions of Classic iFort available via oneAPI
GordonA
We are constrained on the version of iFort we have to use but at the same time keen to move over to the oneAPI. We are currently licensed for XE Composer. Within oneAPI is it possible to select a specific version of the classic (iFort) Fotran compiler? In particular is iFort 18 available?
Ron_Green
Yes, on Intel Registration Center you will see both oneAPI packages and PSXE packages.  Probably too much information but they are separate product SKUs - so each have their past versions visible for download.  So if you want PSXE, under your PSXE Composer Edition, or Pro Ed., or Cluster Ed., click on the current Fortran compiler version and on the next screen you can pull down and select any of the available downloads ( version 18 is the oldest provided)
Ron_Green
GordonA
So to confirm, the oneAPI HPC Tooklit includes access to PSXE 18 and downloads are available via the Registration Center in the usual way.
Steve_Lionel
Right - as long as your support contract is current.
