Very Bad problem -- CYCLE
lklawrie
I will submit this to Premier support but has anyone run into this?  This could be a real show stopper...
I ran the problem file in the debugger....
the code looks something like:
  Do x for number of records in the idf
    select case (object name)
    Case (object name)
       xxx
       CYCLE
    More cases including one with a nested case:
    Now, the debugger jumps to something in the middle there but I don't know if thats true or just a weird thing.
    anywho, jumps to the ENDDO
  ENDDO loop
AND EVERYTHING, Loop variable becomes UNDEFINED and bombs.
And -- this worked in previous versions of IVF
lklawrie
Issue is 687473
Anonymous66
Valued Contributor I
Hello Linda, I am investigating this issue. I will work with you on it through premier support. Regards, Annalee Intel Developer Support
