29656 Discussions
Viewing multidimensional arrays using Intel debugger
bhanu
Hello
I am having problems viewing a multidimensial array using the Intel debugger.
I am using Intel fortran compiler 8.0integrated into .NET.
While I am able to view statically allocated arrays, the debugger says "Invalid Debug Information" for dynamically allocated arrays of dimension 3 or more.
Has anyone else encountered this problem?
Are you using the debugger from within VS.NET or are you using the Intel Debugger (idb)? What is the "package id" of your install of Intel Fortran (w_fc_pc_8.0.???)
bhanu
I am using the intel debugger from within VS.NET and the package id is 035
Bhanu
Ok - please download and install a current compiler - 050 is the latest. If the problem is still present, report it to Intel Premier Support. Please be sure to specify that you are using the debugger in VS.NET.
