29653 Discussions
Virtual memory difference between CVF6 and IF 9.1
galkinv
I built VS2005 task using IF 9.1 library subroutines calls (13 subroutines in 13 files) in debug mode. When I load it under debugger it takes ~116 Mb virtual memory on XP machine. I tried exactly the same task on VS6 and the library on CVF6. As a result virtual memory usage was ~16 Mb. Eight time difference!! I can not belive IF 9.1 is so inefficient. What I did wrong? Here is the listing from the linker when I built VS2005 task using /verbose option for your reference.
------ Rebuild All started: Project: FORTRAN_Q, Configuration: Debug Win32 ------
Deleting intermediate files and output files for project 'FORTRAN_Q', configuration 'Debug|Win32'.
Compiling...
brubyr.cpp
d:ProjectsBruceBbBruceBTasksFORTRAN_Qrubyr.cpp(133) : warning C4244: '=' : conversion from 'double' to 'float', possible loss of data
d:ProjectsBruceBbBruceBTasksFORTRAN_Qrubyr.cpp(135) : warning C4244: '=' : conversion from 'double' to 'float', possible loss of data
Compiling...
RTEX20.cpp
Linking...
Starting pass 1
Processed /DEFAULTLIB:libcpd
Processed /DEFAULTLIB:SimD.lib
Processed /DEFAULTLIB:LIBCD
Processed /DEFAULTLIB:OLDNAMES
LINK : warning LNK4075: ignoring '/EDITANDCONTINUE' due to '/INCREMENTAL:NO' specification
brubyr.obj : LNK9038: module unsafe for SAFESEH image.
RTEX20.obj : LNK9038: module unsafe for SAFESEH image.
Searching libraries
Searching ......3KeyMastersimd.lib:
Found "void * __cdecl GetVar(char *)" (?GetVar@@YAPAXPAD@Z)
Referenced in brubyr.obj
Loaded simd.lib(Sim.obj)
Processed /DEFAULTLIB:uuid.lib
simd.lib(Sim.obj) : LNK9038: module unsafe for SAFESEH image.
Found "int const * const simport_glob_off" (?simport_glob_off@@3PBHB)
Referenced in RTEX20.obj
Loaded simd.lib(SimMain.obj)
simd.lib(SimMain.obj) : LNK9038: module unsafe for SAFESEH image.
Found "char * pTypes" (?pTypes@@3PADA)
Referenced in simd.lib(Sim.obj)
Loaded simd.lib(OpenSM.obj)
simd.lib(OpenSM.obj) : LNK9038: module unsafe for SAFESEH image.
Found "int __cdecl search(struct _Array_ *,int (__cdecl*)(void *,void *),void *,int *)" (?search@@YAHPAU_Array_@@P6AHPAX1@Z1PAH@Z)
Loaded simd.lib(Array.obj)
simd.lib(Array.obj) : LNK9038: module unsafe for SAFESEH image.
Found "char * TaskName" (?TaskName@@3PADA)
Referenced in simd.lib(SimMain.obj)
Referenced in simd.lib(OpenSM.obj)
Loaded simd.lib(TaskName.obj)
Found "int __cdecl TASKCYCLE(void)" (?TASKCYCLE@@YAHXZ)
Loaded simd.lib(TaskCycle.obj)
simd.lib(TaskCycle.obj) : LNK9038: module unsafe for SAFESEH image.
Found _GlobalsInits
Loaded simd.lib(GlobInit.obj)
Found "int nSecurity" (?nSecurity@@3HA)
Loaded simd.lib(Security.obj)
Found "char FloatPointExc" (?FloatPointExc@@3DA)
Referenced in simd.lib(TaskCycle.obj)
Loaded simd.lib(FPExc.obj)
Found "int (__cdecl** Tasks)(void)" (?Tasks@@3PAP6AHXZA)
Loaded simd.lib(TaskList.obj)
Found _DT
Loaded simd.lib(dt.obj)
Found "void __cdecl TASKDONE(void)" (?TASKDONE@@YAXXZ)
Loaded simd.lib(TaskDone.obj)
simd.lib(TaskDone.obj) : LNK9038: module unsafe for SAFESEH image.
Found "void __cdecl TASKINIT(void)" (?TASKINIT@@YAXXZ)
Loaded simd.lib(TaskInit.obj)
simd.lib(TaskInit.obj) : LNK9038: module unsafe for SAFESEH image.
Searching ..librubqd.lib:
Found _BQL@0
Loaded brubqd.lib(brubql.obj)
Processed /DEFAULTLIB:ifconsol
Processed /DEFAULTLIB:libifcore
Processed /DEFAULTLIB:libifport
Processed /DEFAULTLIB:ifwin
Processed /DEFAULTLIB:user32
Processed /DEFAULTLIB:gdi32
Processed /DEFAULTLIB:libm
Processed /DEFAULTLIB:libirc
Found _BQ5F@0
Loaded brubqd.lib(brubq5f.obj)
Found _BQ5@0
Loaded brubqd.lib(brubq5.obj)
Found _BQ4F@0
Loaded brubqd.lib(brubq4f.obj)
Found _BQ4@0
Loaded brubqd.lib(brubq4.obj)
Found _BQ3F@0
Loaded brubqd.lib(brubq3f.obj)
Found _BQ3@0
Loaded brubqd.lib(brubq3.obj)
Found _BQ2F2@0
Loaded brubqd.lib(brubq2f2.obj)
Found _BQ2F1@0
Loaded brubqd.lib(brubq2f1.obj)
Found _BQ2B@0
Loaded brubqd.lib(brubq2b.obj)
Found _BQ2@0
Loaded brubqd.lib(brubq2.obj)
Found _BQ1F@0
Loaded brubqd.lib(brubq1f.obj)
Found _BQ1@0
Loaded brubqd.lib(brubq1.obj)
Searching ..liblookupd.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7libkernel32.lib:
Found __imp__IsBadReadPtr@8
Loaded kernel32.lib(KERNEL32.dll)
Found __imp__UnmapViewOfFile@4
Found __imp__MapViewOfFile@20
Found __imp__CloseHandle@4
Found __imp__CreateFileMappingA@24
Found __imp__CreateFileA@28
Found __imp__WaitForMultipleObjects@16
Found __imp__OpenMutexA@12
Found __i mp__OpenEventA@12
Found __imp__WaitForSingleObject@8
Found __imp__CreateMutexA@12
Found __imp__GetLastError@0
Found __imp__CreateEventA@16
Found __imp__GetCommandLineA@0
Found __imp__GetModuleF
ileNameA@12
Found __imp__MapViewOfFileEx@24
Found __imp__OpenFileMappingA@12
Found __imp__QueryPerformanceCounter@4
Found __imp__QueryPerformanceFrequency@4
Found __imp__SetEvent@4
Found __imp__ResetEvent@4
Found __IMPORT_DESCRIPTOR_KERNEL32
Referenced in kernel32.lib(KERNEL32.dll)
Found __NULL_IMPORT_DESCRIPTOR
Found KERNEL32_NULL_THUNK_DATA
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibuser32.lib:
Found __imp__MessageBeep@4
Loaded user32.lib(USER32.dll)
Found __IMPORT_DESCRIPTOR_USER32
Referenced in user32.lib(USER32.dll)
Found U SER32_NULL_THUNK_DATA
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibgdi32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibwinspool.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibcomdlg32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibadvapi32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibshell32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibole32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKliboleaut32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibuuid.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibodbc32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7PlatformSDKlibodbccp32.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7liblibcpd.lib:
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7libLIBCD.lib:
Found __fltused
Referenced in brubqd.lib(brubq3.obj)
Referenced in brubqd.lib(brubq2.obj)
Referenced in brubqd.lib(brubq1.obj)
Referenced in brubqd.lib(brubql.obj)
Referenced in brubqd.lib(brubq5.obj)
Loaded LIBCD.lib(fpinit.obj)
Found __ftol2
Loaded LIBCD.lib(ftol2.obj)
Found _rand
Loaded LIBCD.lib(rand.obj)
Found _memcpy
Loaded LIBCD.lib(memcpy.obj)
Found _mainCRTStartup
Loaded LIBCD.lib(crt0.obj)
Found _strcmp
Loaded LIBCD.lib(strcmp.obj)
Found __chkesp
Referenced in simd.lib(Array.obj)
Loaded LIBCD.lib(chkesp.obj)
Found __stricmp
Loaded LIBCD.lib(stricmp.obj)
Found _strstr
Loaded LIBCD.lib(strstr.obj)
Found "public: char const * __thiscall type_info::name(void)const " (?name@type_info@@QBEPBDXZ)
Loaded LIBCD.lib(typname.obj)
Found _printf
Loaded LIBCD.lib(printf.obj)
Found _strcat
Loaded LIBCD.lib(strcat.obj)
Found __strnicmp
Loaded LIBCD.lib(strnicmp.obj)
Found _strrchr
Loaded LIBCD.lib(strrchr.obj)
Found _strlen
Referenced in LIBCD.lib(typname.obj)
Loaded LIBCD.lib(strlen.obj)
Found _strcspn
Loaded LIBCD.lib(strcspn.obj)
Found _atoi
Loaded LIBCD.lib(atox.obj)
Found _strncpy
Loaded LIBCD.lib(strncpy.obj)
Found _strncmp
Loaded LIBCD.lib(strncmp.obj)
Found _vprintf
Loaded LIBCD.lib(vprintf.obj)
Found __controlfp
Loaded LIBCD.lib(ieee87.obj)
Found __flsbuf
Loaded LIBCD.lib(_flsbuf.obj)
Found __iob
Referenced in LIBCD.lib(printf.obj)
Referenced in LIBCD.lib(vprintf.obj)
Referenced in LIBCD.lib(_flsbuf.obj)
Loaded LIBCD.lib(_file.obj)
Found _exit
Referenced in LIBCD.lib(crt0.obj)
Loaded LIBCD.lib(crt0dat.obj)
Found __kbhit
Loaded LIBCD.lib(getch.obj)
Found __strupr
Loaded LIBCD.lib(strupr.obj)
Found _strspn
Loaded LIBCD.lib(strspn.obj)
Found _strchr
Loaded LIBCD.lib(strchr.obj)
Found _malloc
Loaded LIBCD.lib(dbgheap.obj)
Found _memmove
Loaded LIBCD.lib(memmove.obj)
Found __fpieee_flt
Loaded LIBCD.lib(filter.obj)
Found _memset
Referenced in LIBCD.lib(dbgheap.obj)
Loaded LIBCD.lib(memset.obj)
Found __alldiv
Loaded LIBCD.lib(lldiv.obj)
Found __allmul
Referenced in LIBCD.lib(atox.obj)
Loaded LIBCD.lib(llmul.obj)
Found __except_list
Referenced in LIBCD.lib(getch.obj)
Referenced in LIBCD.lib(strupr.obj)
Loaded LIBCD.lib(exsup.obj)
Found __except_handler3
Loaded LIBCD.lib(exsup3.obj)
Found __chkstk
Referenced in brubqd.lib(brubq1f.obj)
Referenced in brubqd.lib(brubq5f.obj)
Referenced in brubqd.lib(brubq4f.obj)
Referenced in brubqd.lib(brubq2f2.obj)
Referenced in brubqd.lib(brubq2f1.obj)
Loaded LIBCD.lib(chkstk.obj)
Found __setdefaultprecision
Referenced in LIBCD.lib(fpinit.obj)
Referenced in LIBCD.lib(ieee87.obj)
Loaded LIBCD.lib(fp8.obj)
Found __ms_p5_mp_test_fdiv
Loaded LIBCD.lib(testfdiv.obj)
Found __positive
Loaded LIBCD.lib(cvt.obj)
Found __cfltcvt_tab
Loaded LIBCD.lib(cmiscdat.obj)
Found __XcptFilter
Loaded LIBCD.lib(winxfltr.obj)
Found __setenvp
Loaded LIBCD.lib(stdenvp.obj)
Found __setargv
Referenced in LIB
CD.lib(crt0.obj)
Loaded LIBCD.lib(stdargv.obj)
Found ___crtGetEnvironmentStringsA
Loaded LIBCD.lib(a_env.obj)
Found __ioinit
Loaded LIBCD.lib(ioinit.obj)
Found __RTC_Initialize
Loaded LIBCD.lib(initsect.obj)
Found __heap_init
Loaded LIBCD.lib(heapinit.obj)
Found __NMSG_WRITE
Loaded LIBCD.lib(crt0msg.obj)
Found __CrtDbgReport
Referenced in LIBCD.lib(filter.obj)
Referenced in LIBCD.lib(crt0msg.obj)
Referenced in LIBCD.lib(chkesp.obj)
Loaded LIBCD.lib(dbgrpt.obj)
Found _tolower
Referenced in LIBCD.lib(stricmp.obj)
Referenced in LIBCD.lib(strnicmp.obj)
Referenced in LIBCD.lib(cvt.obj)
Loaded LIBCD.lib(tolower.obj)
Found ___ascii_stricmp
Loaded LIBCD.lib(_stricmp.obj)
Found ___lc_handle
Referenced in LIBCD.lib(tolower.obj)
Loaded LIBCD.lib(nlsdata2.obj)
Found ___unDName
Loaded LIBCD.lib(undname.obj)
Found __malloc_base
Loaded LIBCD.lib(malloc.obj)
Found __free_base
Loaded LIBCD.lib(free.obj)
Found __ftbuf
Loaded LIBCD.lib(_sftbuf.obj)
Found __output
Loaded LIBCD.lib(output.obj)
Found ___ascii_strnicmp
Loaded LIBCD.lib(_strnicm.obj)
Found __ismbcspace
Loaded LIBCD.lib(ismbspc.obj)
Found __lseek
Loaded LIBCD.lib(lseek.obj)
Found __write
Loaded LIBCD.lib(write.obj)
Found __getbuf
Loaded LIBCD.lib(_getbuf.obj)
Found __isatty
Referenced in LIBCD.lib(_sftbuf.obj)
Loaded LIBCD.lib(isatty.obj)
Found __fcloseall
Referenced in LIBCD.lib(_file.obj)
Loaded LIBCD.lib(closeall.obj)
Found __flushall
Loaded LIBCD.lib(fflush.obj)
Found ___xc_a
Referenced in LIBCD.lib(crt0dat.obj)
Loaded LIBCD.lib(crt0init.obj)
Processed /DEFAULTLIB:kernel32.lib
Processed /DISALLOWLIB:libc.lib
Processed /DISALLOWLIB:libcmt.lib
Processed /DISALLOWLIB:libcmtd.lib
Processed /DISALLOWLIB:msvcrt.lib
Processed /DISALLOWLIB:msvcrtd.lib
Found _atexit
Loaded LIBCD.lib(onexit.obj)
Found ___initconin
Loaded LIBCD.lib(initcon.obj)
Found __putch
Loaded LIBCD.lib(putch.obj)
Found __resetstkoflw
Loaded LIBCD.lib(resetstk.obj)
Found ___crtLCMapStringA
Loaded LIBCD.lib(a_map.obj)
Found __newmode
Referenced in LIBCD.lib(malloc.obj)
Loaded LIBCD.lib(_newmode.obj)
Found __callnewh
Loaded LIBCD.lib(handler.obj)
Found __pfnAllocHook
Loaded LIBCD.lib(dbghook.obj)
Found __expand_base
Loaded LIBCD.lib(expand.obj)
Found __realloc_base
Loaded LIBCD.lib(realloc.obj)
Found __heapchk
Loaded LIBCD.lib(heapchk.obj)
Found ___sbh_verify_block
Loaded LIBCD.lib(sbheap.obj)
Found _sprintf
Loaded LIBCD.lib(sprintf.obj)
Found __chvalidator
Referenced in LIBCD.lib(ismbspc.obj)
Loaded LIBCD.lib(isctype.obj)
Found ___mb_cur_max
Loaded LIBCD.lib(nlsdata1.obj)
Found ___security_cookie
Referenced in LIBCD.lib(undname.obj)
Referenced in LIBCD.lib(output.obj)
Referenced in LIBCD.lib(write.obj)
Referenced in LIBCD.lib(dbgrpt.obj)
Loaded LIBCD.lib(seccook.obj)
Found @__security_check_cookie@4
Loaded LIBCD.lib(secchk.obj)
Found _fpieee_flt_simd
Loaded LIBCD.lib(filter_simd.obj)
Found __ValidateEH3RN
Referenced in LIBCD.lib(exsup3.obj)
Loaded LIBCD.lib(eh3valid.obj)
Found __atoflt
Loaded L IBCD.lib(intrncvt.obj)
Found __fptostr
Loaded LIBCD.lib(_fptostr.obj)
Found __fltout
Loaded LIBCD.lib(cfout.obj)
Found __fptrap
Referenced in LIBCD.lib(cmiscdat.obj)
Loaded LIBCD.lib(crt0fp.obj)
Found ___initmbctable
Referenced in LIBCD.lib(stdenvp.obj)
Referenced in LIBCD.lib(stdargv.obj)
Loaded LIBCD.lib(mbctype.obj)
Found ___crtMessageBoxA
Loaded LIBCD.lib(crtmbox.obj)
Found __itoa
Loaded LIBCD.lib(xtoa.obj)
Found __snprintf
Loaded LIBCD.lib(snprintf.obj)
Found __vsnprintf
Loaded LIBCD.lib(vsnpri
nt.obj)
Found _raise
Loaded LIBCD.lib(winsig.obj)
Found __pctype
Referenced in LIBCD.lib(isctype.obj)
Loaded LIBCD.lib(ctype.obj)
Found __allshl
Loaded LIBCD.lib(llshl.obj)
Found __aulldiv
Referenced in LIBCD.lib(xtoa.obj)
Loaded LIBCD.lib(ulldiv.obj)
Found __aullrem
Loaded LIBCD.lib(ullrem.obj)
Found __purecall
Loaded LIBCD.lib(purevirt.obj)
Found _wctomb
Loaded LIBCD.lib(wctomb.obj)
Found ___crtGetStringTypeA
Referenced in LIBCD.lib(mbctype.obj)
Loaded LIBCD.lib(a_str.obj)
Found __dosmaperr
Referenced in LIBCD.lib(lseek.obj)
Loaded LIBCD.lib(dosmap.obj)
Found __get_osfhandle
Loaded LIBCD.lib(osfinfo.obj)
Found __lseeki64
Loaded LIBCD.lib(lseeki64.obj)
Found _fclose
Referenced in LIBCD.lib(closeall.obj)
Loaded LIBCD.lib(fclose.obj)
Found __commit
Referenced in LIBCD.lib(fflush.obj)
Loaded LIBCD.lib(commit.obj)
Found ___convertcp
Referenced in LIBCD.lib(a_map.obj)
Referenced in LIBCD.lib(a_str.obj)
Loaded LIBCD.lib(convrtcp.obj)
Found ___security_init_cookie
Referenced in LIBCD.lib(secchk.obj)
Loaded LIBCD.lib(seccinit.obj)
Found ___secur
ity_error_handler
Loaded LIBCD.lib(secfail.obj)
Found _XMMI_FP_Emulation
Referenced in LIBCD.lib(filter_simd.obj)
Loaded LIBCD.lib(xmmi_fp_emul.obj)
Found _XMMI2_FP_Emulation
Loaded LIBCD.lib(xmmi2_fp_emul.obj)
Found ___addl
Referenced in LIBCD.lib(intrncvt.obj)
Loaded LIBCD.li b(mantold.obj)
Found ___strgtold12
Loaded LIBCD.lib(strgtold.obj)
Found _$I10_OUTPUT
Referenced in LIBCD.lib(cfout.obj)
Loaded LIBCD.lib(x10fout.obj)
Found __close
Referenced in LIBCD.lib(fclose.obj)
Loaded LIBCD.lib(close.obj)
Found __freebuf
Loaded LIBCD.lib(_freebuf.obj)
Found ___multtenpow12
Referenced in LIBCD.lib(strgtold.obj)
Referenced in LIBCD.lib(x10fout.obj)
Loaded LIBCD.lib(tenpow.obj)
Found __pow10neg
Referenced in LIBCD.lib(tenpow.obj)
Loaded LIBCD.lib(constpow.obj)
Searching D:Program FilesMicrosoft Visual Studio .NET 2003Vc7libOLDNAMES.lib:
Searching C:Program FilesIntelCompilerFortran9.1IA32Libifconsol.lib:
Searching C:Program FilesIntelCompilerFortran9.1IA32Liblibifcore.lib:
Searching C:Program FilesIntelCompilerFortran9.1IA32Liblibifport.lib:
Searching C:Program FilesIntelCompilerFortran9.1IA32Libifwin.lib:
Searching C:Program FilesIntelCompilerFortran9.1IA32Liblibm.lib:
Searching C:Program FilesIntelCompilerFortran9.1IA32Liblibirc.lib:
Found __imp__GetVersionExA@4
Found __imp__GetModuleHandleA@4
Referenced in LIBCD.lib(testfdiv.obj)
Found __imp__TerminateProcess@8
Found __imp__GetCurrentProcess@0
Found __imp__ExitProcess@4
Found __imp__GetProcAddress@8
Referenced in LIBCD.lib(crtmbox.obj)
Found __imp__ReadConsoleInputA@16
Found __imp__SetConsoleMode@8
Found __imp__GetConsoleMode@8
Found __imp__PeekConsoleInputA@16
Found __imp__GetNumberOfConsoleInputEvents@8
Found __imp__IsBadWritePtr@8
Referenced in LIBCD.lib(sbheap.obj)
Found __imp__HeapValidate@12
Referenced in LIBCD.lib(heapchk.obj)
Loaded kernel32.lib(KER NEL32.dll)
Found _RtlUnwind@16
Referenced in LIBCD.lib(exsup.obj)
Found __imp__UnhandledExceptionFilter@4
Referenced in LIBCD.lib(winxfltr.obj)
Found __imp__FreeEnvironmentStringsA@4
Referenced in LIBCD.lib(a_env.obj)
Found __imp__GetEnvironmentStrings@0
Found __imp__FreeEnvironmentStringsW@4
Found __imp__WideCharToMultiByte@32
Referenced in LIBCD.lib(wctomb.obj)
Referenced in LIBCD.lib(convrtcp.obj)
Found __imp__GetEnvironmentStringsW@0
Found __imp__SetHandleCount@4
Referenced in LIBCD.lib(ioinit.obj)
Found __imp__GetStdHandle@4
Found __imp__GetFileType@4
Referenced in LIBCD.lib(osfinfo.obj)
Found __imp__G
etStartupInfoA@4
Found __imp__HeapDestroy@4
Referenced in LIBCD.lib(heapinit.obj)
Found __imp__HeapCreate@12
Found __imp__HeapFree@12
Referenced in LIBCD.lib(free.obj)
Found __imp__VirtualFree@12
Found __imp__WriteFile@20
Found __imp__DebugBreak@0
Found __imp__InterlockedDecrement@4
Found __imp__OutputDebugStringA@4
Found __imp__LoadLibraryA@4
Found __imp__InterlockedIncrement@4
Found __imp__HeapAlloc@12
Referenced in LIBCD.lib(realloc.obj)
Found __imp__SetFilePointer@16
Referenced in L IBCD.lib(lseeki64.obj)
Found __imp__WriteConsoleA@20
Referenced in LIBCD.lib(putch.obj)
Found __imp__VirtualProtect@16
Referenced in LIBCD.lib(resetstk.obj)
Found __imp__VirtualAlloc@16
Found __imp__GetSystemInfo@4
Found __imp__VirtualQuery@12
Referenced in LIBCD.lib(eh3valid.obj)
Found __imp__MultiByteToWideChar@24
Found __imp__LCMapStringA@24
Found __imp__LCMapStringW@24
Found __imp__HeapReAlloc@16
Referenced in LIBCD.lib(expand.obj)
Found __imp__InterlockedExchange@8
Found __imp__GetCPInfo@8
Found __imp__GetACP@0
Found __imp__GetOEMCP@0
Found __imp__SetConsoleCtrlHandler@8
Referenced in LIBCD.lib(winsig.obj)
Found __imp__GetSt
ringTypeA@20
Found __imp__GetStringTypeW@16
Found __imp__SetStdHandle@8
Found __imp__FlushFileBuffers@4
Referenced in LIBCD.lib(commit.obj)
Found __imp__GetLocaleInfoA@16
Found __imp__GetTickCount@0
Referenced in LIBCD.lib(seccinit.obj)
Found __imp__GetCurrentThreadId@0
Found __imp__GetCurrentProcessId@0
Found __imp__GetSystemTimeAsFileTime@4
Finished searching libraries
Finished pass 1
Generating non-SAFESEH image.
Starting pass 2
RTEX20.obj
brubyr.obj
simd.lib(Array.obj)
simd.lib(dt.obj)
simd.lib (FPExc.obj)
simd.lib(GlobInit.obj) : warning LNK4099: PDB 'vc60.pdb' was not found with '......3KeyMastersimd.lib' or at 'd:ProjectsBruceBbBruceBTasksFortran_qDebugvc60.pdb'; linking object as if no debug info
simd.lib(OpenSM.obj) : warning LNK4099: PDB 'vc60.pdb' was not found with '......3KeyMastersimd.lib' or at 'd:ProjectsBruceBbBruceBTasksFortran_qDebugvc60.pdb'; linking object as if no debug info
simd.lib(Sim.obj)
simd.lib(Sim.obj) : warning LNK4099: PDB 'vc60.pdb' was not found with '......3KeyMastersimd.lib' or at 'd:ProjectsBruceBbBruceBTasksFortran_qDebugvc60.pdb'; linking object as if no debug info
simd.lib(SimMain.obj) : warning LNK4099: PDB 'vc60.pdb' was not found with '......3KeyMastersimd.lib' or at 'd:ProjectsBruceBbBruceBTasksFortran_qDebugvc60.pdb'; linking object as if no debug info
simd.lib(TaskCycle.obj) : warning LNK4099: PDB 'vc60.pdb' was not found with '......3KeyMastersimd.lib' or at 'd:ProjectsBruceBbBruceBTasksFortran_qDebugvc60.pdb'; linking object as if no debug info
simd.lib(TaskList.obj) : warning LNK4099: PDB 'vc60.pdb' was not found with '......3KeyMastersimd.lib' or at 'd:ProjectsBruceBbBruceBTasksFortran_qDebugvc60.pdb'; linking object as if no debug info
kernel32.lib(KERNEL32.d ll)
kernel32.l
b(KERNEL32.dll)
LIBCD.lib(mantold.obj)
LIBCD.lib(cvt.obj)
LIBCD.lib(vsnprint.obj)
LIBCD.lib(fp8.obj)
LIBCD.lib(crt0.obj)
LIBCD.lib(rand.obj)
LIBCD.lib(free
.obj)
LIBCD.lib(xtoa.obj)
LIBCD.lib(atox.obj)
Finished pass 2
Build log was saved at "file://d:ProjectsBruceBbBruceBTasksFortran_qDebugBuildLog.htm"
FORTRAN_Q - 0 error(s), 9 warning(s)
---------------------- Done ----------------------
Rebuild All: 1 succeeded, 0 failed, 0 skipped
The output you posted is for a Visual C++ project. It isn't helpful in resolving your issue regarding Intel Visual Fortran.
Does your Visual Studio solution have many projects? I have seen in the past a virtual memory use issue when there are many Fortran projects, but that should have been resolved some months ago. Do you have to start the program under the debugger to see this VM use or is it just when VS2005 is running?
A link map might be more informative.
If you think there is a problem, please submit an issue to Intel Premier Support and attach a buildable and runnable project (ZIP of your project folder(s), and we'll take a look.
galkinv
Could you give me the reference to Intel Premier Support, so I can send theVS2005 project and IF 9.1 library zipped? I actually have pretty big number of fortran libraries (19) and I am really in troubleusing IF 9.1.
Start here.
