Looking at the version of kernel32.f90 in C:\Program Files (x86)\Intel\Composer XE 2015\compiler\include
INTERFACE
FUNCTION VirtualProtect( &
lpAddress, &
dwSize, &
flNewProtect, &
lpflOldProtect)
import
integer(BOOL) :: VirtualProtect ! BOOL
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'VirtualProtect' :: VirtualProtect
integer(LPVOID) lpAddress ! LPVOID lpAddress
integer(SIZE_T) dwSize ! SIZE_T dwSize
integer(DWORD) flNewProtect ! DWORD flNewProtect
integer(LPDWORD) lpflOldProtect ! PDWORD lpflOldProtect
END FUNCTION
END INTERFACE
And then the version in C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.3.210\windows\compiler\include
INTERFACE
lpAddress, &
dwSize, &
flNewProtect, &
lpflOldProtect)
import
integer(DWORD) lpflOldProtect ! PDWORD lpflOldProtect
!DEC$ ATTRIBUTES REFERENCE, IGNORE_LOC :: lpflOldProtect
END FUNCTION
END INTERFACE
Running a 64-bit executable, the call in the older ifort version succeeds. The call in the newer version fails. May I suggest, from:
https://msdn.microsoft.com/en-us/library/windows/desktop/aa366898(v=vs.85).aspx
That the correct declaration should be:
INTERFACE
. lpAddress,
. dwSize,
. flNewProtect,
. pflOldProtect)
import
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE :: VirtualProtect
!DEC$ ATTRIBUTES ALIAS:'VirtualProtect' :: VirtualProtect
integer(PDWORD) pflOldProtect ! PDWORD lpflOldProtect
END FUNCTION
END INTERFACE
Unless I am misreading the documentation, which I suppose is possible, the new interface is correct and should work with old sources that passed LOC(old-protect-variable). The goal of the change, and there are a lot of these in the modules, is to replace "address by value" with "correctly-typed-thing by reference". The IGNORE_LOC allows old code to continue to work.
Can you provide a short but complete example showing what fails (and please elaborate on "fails")?
This should work with any DLL and function, I picked out dbghelp from v7.1 Windows API (I believe the error is in 4-byte vs 8-byte):
program main USE KERNEL32 USE IFWINTY USE ISO_C_BINDING INTEGER(HANDLE)hLib TYPE(C_PTR) PATCHLOC1 INTEGER(DWORD)iGetLastError CHARACTER(100)SLIB SLIB= & "C:\\Program Files\\Debugging Tools for Windows (x64)\\"// & "dbghelp.dll"c hLib=LoadLibrary(SLIB) PATCHLOC1=TRANSFER(GetProcAddress(hLib,"StackWalk64"C),PATCHLOC1) CALL DoCrash(PATCHLOC1) END subroutine DoCrash(PFORIGINAL) use kernel32 USE ISO_C_BINDING C TYPE(C_PTR), INTENT(IN) :: PFORIGINAL INTEGER(LPVOID) FPFORIGINAL TYPE(C_PTR) CPTR_OLDPROTECT INTEGER(DWORD) OLDPROTECT INTEGER(PDWORD) FPTR_OLDPROTECT INTEGER(BOOL) BSUCCESS INTEGER(SIZE_T) SIZE C FPFORIGINAL = TRANSFER(PFORIGINAL,FPFORIGINAL) CPTR_OLDPROTECT = C_LOC(OLDPROTECT) FPTR_OLDPROTECT = TRANSFER(CPTR_OLDPROTECT,FPTR_OLDPROTECT) SIZE = 50 BSUCCESS = VirtualProtect(FPFORIGINAL,SIZE,PAGE_READWRITE, & FPTR_OLDPROTECT) IF (BSUCCESS == 0) THEN WRITE(*,*)"Uh oh, failed!" ENDIF C Now, Undo BSUCCESS = VirtualProtect(FPFORIGINAL,SIZE,OLDPROTECT, & FPTR_OLDPROTECT) IF (BSUCCESS == 0) THEN WRITE(*,*)"Uh oh, failed!" ENDIF end subroutine
I forgot to mention, the old compiler executes this with both BSUCCESS values being 1, while the new compiler sets BSUCCESS = 0 on the second call.
This fails for you because you're constructing the OLDPROTECT pointer manually, which is unnecessary and not typical. This works with the new interface.
use kernel32
USE ISO_C_BINDING
C
! TYPE(C_PTR) CPTR_OLDPROTECT
C
!CPTR_OLDPROTECT = C_LOC(OLDPROTECT)
!FPTR_OLDPROTECT = TRANSFER(CPTR_OLDPROTECT,FPTR_OLDPROTECT)
SIZE = 50
& OLDPROTECT)
ENDIF
C Now, Undo
& OLDPROTECT)
ENDIF
end subroutine
And this (snippet) works with both old and new:
& LOC(OLDPROTECT))
ENDIF
C Now, Undo
& LOC(OLDPROTECT))
Note that you get a compile error with the way you had it, which would be a clue that something needs to change.
