Visious complier bug...
FlyingHermes
I've attached a compressed file containing the source code which reproduce a compiler bug. I've done my best to try to isolate the lines of code which trigger the bug.
The bug seems to be linked to the use statement. For example, the following implementation of the DataTmp_Class procedure results in a compiler bug:
[fortran]Module DataTmp_Class
  implicit none
  private
  public        DataTmp_Type
  Type                          ::      DataTmp_Type
  contains
    procedure   ,private        ::      Set_Var1
    procedure   ,private        ::      Set_Var2
    procedure   ,private        ::      Set_Var3
  End Type
  contains
Subroutine Set_Var1( This, AllData )
  use AllData_Class              ,only:  AllData_Type
  implicit none
  class(DataTmp_Type)  ,intent(inout)  ::      This
  type(AllData_Type)    ,dimension(:)   ,intent(in)     ::      AllData
End Subroutine
Subroutine Set_Var2( This, AllData )
  implicit none
End Subroutine
Subroutine Set_Var3( This, AllData )
  implicit none
End Subroutine
End Module[/fortran]
whereas this one doesn't:
  implicit none
  private
  public        DataTmp_Type
  contains
  End Type
  contains
!   use AllData_Class              ,only:  AllData_Type
  implicit none
End Subroutine
  implicit none
End Subroutine
  implicit none
End Subroutine
The difference between the two implementation is that AllData_Type type is made accessible through host association to the entire module instead that to each individual procedures.
Note that the initial error message (also related to a compiler bug) was not the one I have now, after having reduced to code to a minimum example. I guess the two bugs are connected but I'm not sure. This initial bug was located in the MainObj_Class file (at least, that what the error message was saying) and it was vanishing if I was removing the AllData structure of type AllData_Type.
I hope I'm clear enougth.
Thanks - I can reproduce the error and will escalate it to the developers. Issue ID is DPD200240402.
This was fixed in update 4 or 5.
