Visual Fortran, EXCEL and AUTODICE
schotti
Dear all,
I am runningIVF 11.1.067 compiler and upgraded to IVF version 12 last week. I use FORTRAN code which executes EXCEL calls based on the AUTODICE example. My Office version is2007 (version 12).
So far - until last week - the program(built with 11.1.067 or earlier versions) ran successfully on different computers - independent of the EXCEL versionlocally installed. The only compromise was to selectWindows language as: English(US) to avoid execution failure.
However, now I encounter similar problems like Leonhard Bergstroem last July. Surprisingly, after de-installationof version 12 back to version 11.1.067 the problem remains. I can no longer maintain EXCEL sheets from within my FORTRAN program. Executions end with program crash.
I use COMCREATEOBJECT with "Excel.Application" (as generic call). Testing with "Excel.Application.12" (corresponding to my office version) gavethe same error on calling COMCREATEOBJECT: exception code 0x235 (565) - "invalid signal error". The problem is an assertion failure in some "C" routine called "winsig.c", line 419.
To make sure that I have no formal error in my code - I built the original AUTODICE example and also COMCREATEOBJECT fails to create an EXCEL object (error 0x235 (565)).
To be clearly understood - the old linked programs are still executing properly.However, I have nochance any more to maintain the code (!) with the current situation.
As I am no C programmer - I need desparately "good advice".
Thank you all
schotti
JUST A SHORT EXYENSION TO THE PROBLEM ABOVE:
if the code is compiled with the "Release" option - everthing works fine !
Apparently the IVF debugger ist the problem.
I can build and run the AUTODICE sample with Composer XE in Debug mode and don't see any errors. I have Excel 2007 on my system. I suggest you try unzipping the COM.zip sample package into a new folder and try building and running that without changes.
Which Visual Studio version are you using?
schotti
Sorry for answering so late.
My Visual Studio version is 2008.
In the installation of XE composer I selected to keep this version which I have used successfully before.
As to the AUTODICE example I tested: I did already exactly what you proposed.
None-the-less I encounter the crash under DEBUG mode and I find properly exeuting code under RELEASE.
I have re-installed 11.01.067 version hoping to sort out the problem - but now I find the result as with COMPOSER XE. So the secret must be somewhere in the installation of COMPOSER XE. It looks like something waschanged on my system - but I have absolutely no idea what that might be.
Try this experiment. Uninstall 11.1 and delete the "Intel Fortran" directory under Visual Studio 9. Reinstall 11.1 and try AUTODICE again. What happens? I doubt there will be a difference, but one never knows. I am not aware that there's anything that we install that would affect this behavior. Maybe other people here can try this experiment for themselves and report the results.
