I have been trying to compile my Visual Fortran Code, Using Message Passing Interface Libraries, (using NT-MPICH 1.3.1a) and run the code on a cluster of machines. I have run into some difficulty with the Windows SP2 Patch and the plug-in that i need to use.
I need to use the active plug-in ch_wsock. When i run my code in Command Prompt, no matter how many machines i tell it to use to run my code, it runs the code on one machine only at a time.
Does anyone know what the problem may be? is there any changes i need to make in the Visual Fortran environments or any other part of Visual Fortran?
I Have updated to Visual Fortran 6.6 with the "C"update. I have also installed winsockfix, on my compiling machine.
Can anyone help?
