Visual Studio Source edit problem
andrew_4619
The last few days I have been getting an intermittent/occasional problem editing Fortran source files in Visual studio.
The edit window appears to be unresponsive but what is actually happing is that input is appearing at the top of the file (after any comments but before the first Fortran statement - i.e. just above the first "-" for the outlining) and not at the current cursor position. If I then close the file (it saves OK) an error box appears with:
"Visual Studio has encountered an exception. This my be caused by an extension".  If I open the file again it works OK until the problem "randomly" strikes again.
I am using VS2010 shell and using the latest versions of Fortran. This problem has been evident since I installed the latest updates.
Anyone else seen this and/or got and ideas?
This symptom is not familiar to me. Have you installed VS2010 SP1?
andrew_4619
Yes, the products are listed below:
Microsoft Visual Studio 2010
Version 10.0.40219.1 SP1Rel
Microsoft .NET Framework
Version 4.5.50938 SP1Rel
Installed Version: IDE Standard
Microsoft Visual Web Developer 2010   01011-532-2002361-70752
Hotfix for Visual Studio 2010 Shell (Integrated) - ENU (KB2548139)   KB2548139
This hotfix is for Visual Studio 2010 Shell (Integrated) - ENU.
If you later install a more recent service pack, this hotfix will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/2548139.
Hotfix for Visual Studio 2010 Shell (Integrated) - ENU (KB2549864)   KB2549864
For more information, visit http://support.microsoft.com/kb/2549864.
Hotfix for Visual Studio 2010 Shell (Integrated) - ENU (KB2635973)   KB2635973
For more information, visit http://support.microsoft.com/kb/2635973.
Intel(R) Visual Fortran     Package ID: w_fcompxe_2013_sp1.2.176
Intel(R) Visual Fortran Composer XE 2013 SP1 Update 2 Integration for Microsoft Visual Studio* 2010, 14.0.0086.2010, Copyright (C) 2002-2014 Intel Corporation
* Other names and brands may be claimed as the property of others.
Intel® Advisor XE 2013 Update 5
Intel® Advisor XE 2013 Update 5, (build 316162), Copyright © 2009-2013 Intel Corporation. All rights reserved.
Intel® Inspector XE 2013 Update 9
Intel® Inspector XE 2013 Update 9, (build 328075), Copyright © 2009-2013 Intel Corporation. All rights reserved.
Intel® VTune™ Amplifier XE 2013 Update 15
Intel® VTune™ Amplifier XE 2013 Update 15, (build 328102), Copyright © 2009-2013 Intel Corporation. All rights reserved.
MySQL Connector/Net   6.6.5
Data design and management tools for MySQL.  Copyright © 2007-2011 Oracle, Inc.
Security Update for Visual Studio 2010 Shell (Integrated) - ENU (KB2644980)   KB2644980
This security update is for Visual Studio 2010 Shell (Integrated) - ENU.
If you later install a more recent service pack, this security update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/2644980.
Security Update for Visual Studio 2010 Shell (Integrated) - ENU (KB2645410)   KB2645410
For more information, visit http://support.microsoft.com/kb/2645410.
Visual Studio 2010 Shell (Integrated) - ENU Service Pack 1 (KB983509)   KB983509
This service pack is for Visual Studio 2010 Shell (Integrated) - ENU.
If you later install a more recent service pack, this service pack will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/983509.
andrew_4619
This problem went away but is now randomly striking again from time to time.I am still on VS2010 shell and up to date with updates....
My usual suggestion here - uninstall Fortran, delete the Intel Fortran folder under Visual Studio 10.0, reinstall Fortran. You don't need to uninstall VS Shell. This sometimes fixes weird problems.
