Visual Studio Ultimate
Dave_A__from_Lifeboa
I have a customer who wants to install and use Visual Studio Ultimate with Intel Fortran Composer with IMSL. Problems? Suggestions? Do's or don'ts?
thanks.....Dave A. from Lifeboat.
No problem, as long as it is VS2005, 2008 or 2010. Please ask the customer to read Installing and Configuring the IMSL* Libraries
Thanks Steve !!
saineyl
I've installed visual studio ultimate and the Intel c++ studio.
I'm trying to follow the "Intel C++ Composer XE 2011 GettingStarted Tutorials" but can't find some of the properties described in the tutorial (I do see under project->Intel c++ composer...).
For exmaple:
* Preparing Applications for Parallel Debugging:
1. Select Configuration Properties > C/C++ > Debug in the left pane.
2. Under Enable Parallel Debug Checks, select Yes (/debug:parallel)
(I can't find "Enable paralkel...).
* Under Project > Properties, I don't see the "Intel Specific" definitions.
What am I missing?
Lior
Which version of Visual Studio? If it is "Visual Studio 11", that is not yet supported.
TimP
The easily accessible version of VS11 doesn't even include C++.
In order to see the "Intel specific" project properties, you have to right click on the project and select Intel Composer XE 2011 > Use Intel C++. Perhaps that is what is missing here?
