29487 Discussions
Visual Studio cannot debug because <x> is not an EXE file
Luis_M_
I am trying to port a compaq FORTRAN app to Intel v11.  No compilation error, the app runs from the cmd prompt.  There was a topic that is now closed but looked similar.  No luck.
Help would be appreciated
Arjen_Markus
So what is the problem?
Luis_M_
I cannot debug the app.  I uploaded a screen capture of the message.
andrew_4619
Do a full rebuild and post the buildlog (a html file) which will show what has happened.
Luis_M_
I already tried but saw nothing obviously wrong. Log attached with txt extension.
Kevin_D_Intel
So it does not run under the VS IDE with either Debugging or Without Debugging?
Any possible settings under Properties > Debugging > Command that might be at play?
Luis_M_
Nope.
I just tried a test program (same default settings) that uses the same libraries (that I suspected could give me trouble) but it works fine.  It looks like VS is choking on the size or complexity of the app.
Lorri_M_Intel
It is, quite likely, too big.
I see that you are using /libs:static.   Can you try linking against the DLL libraries instead?  That should make your executable smaller.
                          --Lorri
