I just installed Intel Fortran with Visual Studio 2008 Professional (the full Microsoft product, not the shell) on Windows 7 Ultimate x64.
The Fortran documentation is present in the Visual Studio help system. I can browse it, and I can see it in the Contents and Index panes.
But the search function never returns any results from the Fortran documentation.
The search function has drop-down menus for "Language", "Technology", and "Content Type" but none of the drop-downs refer to Fortran or Intel. And it doesn't matter what I select in the drop-downs, the search function just can't see the Fortran documentation.
Is something wrong with my installation, or is the help search function not supported?
I reinstalled Fortran 3 times, and reinstalled the MSDN library once, and there has been some improvement.
Now, if all three of the filters (Language, Technology, and Content Type) are set to "All", then the search function can see the Fortran documentation. Otherwise, the search function does not see the Fortran documentation.
That means there is no way to limit the search to just the Fortran documentation. With the filters set to "All" searches return matches not only in the Fortran documentation but also the entire MSDN library.
It's not ideal, but it's useable. I don't know what else to try.
Do this.
Open a command prompt window.
Set your default (cd) to C:\Program Files\Intel\Compiler\11.1\060\help [if you are using a different version, substitute the appropriate path here).
Type the following commands for the VS versions you have:
h2reg -r CmdFile=..\Documentation\vshelp\1033\intel.forprodocs.en\fproc_vs2008_H2Reg_cmd.ini
h2reg -r CmdFile=..\Documentation\vshelp\1033\intel.forprodocs.en\fproc_vs2005_H2Reg_cmd.ini
h2reg -r CmdFile=..\Documentation\vshelp\1033\intel.forprodocs.en\fproc_vs2003_H2Reg_cmd.ini
Type the following commands:
h2reg -r CmdFile=..\Documentation\vshelp\1033\intel.debuggerdocs_f.en\H2Reg_cmd_idb_f.ini
h2reg -r CmdFile=..\Documentation\vshelp\1033\\intel.fprocompilerdocs.en\H2Reg_cmd.ini
Let me know how this works for you.
