29656 Discussions
Visual studio debugger reports incorrect variable values
Terry_Gerald1
I have a user defined type with type bound procedures.
When stepping inside any of the type-bound procedures with the VS Debugger, a query of type variables yields total nonsense for any and all variables.
The debugger doesn't seem to understand the "this" pointer.
Note: If I print ("write(*,*) var_name" )out the variable values, the correct values are written to the screen.
Edited code below is similar to what I am running
module FSM_module
implicit none
integer, parameter :: fpx = 4
type :: sed_reactor_type
integer :: number_layers
real(kind=fpx) :: area
real(kind=fpx), dimension(:), allocatable :: flow_
real(kind=fpx), dimension(:), allocatable :: width_
real(kind=fpx), dimension(:), allocatable :: d_
real(kind=fpx), dimension(:), allocatable :: conc_
real(kind=fpx), dimension(:), allocatable :: dss_
real(kind=fpx), dimension(:), allocatable :: fd_
real(kind=fpx) :: concTop = 0
real(kind=fpx) :: concBottom = 0
real(kind=fpx) :: fluxTop = 0
real(kind=fpx) :: fluxBottom = 0
contains
procedure :: set_flow => FSM_set_flow
procedure :: set_conc => FSM_set_conc
end type
private :: FSM_set_flow, FSM_set_conc
contains
subroutine FSM_set_width(this, values, srp)
class(sed_reactor_type) :: this
real(kind=fpx), dimension(*) :: values
type(sed_reactor_type), pointer :: srp
integer :: n
real(kind=fpx) :: depth = 0;
this%width_(0) = values(1)
do n=1, this%number_layers
this%width_(n) = values(n)
this%d_(n) = depth
depth = depth + values(n)
end do
this%width_(this%number_layers+1) = values(this%number_layers)
end subroutine FSM_set_width
subroutine FSM_set_conc(this, values, srp)
class (sed_reactor_type) :: this
integer :: n
this%conc_(0) = values(1)
this%conc_(n) = values(n)
end do
this%conc_(this%number_layers+1) = values(this%number_layers)
end subroutine FSM_set_conc
end module FSM_module
Terry_Gerald1
Well, I guess you cant cut and past from visual studio!
mecej4
For pasting code, copy as text at the source, click on the "Insert Code using Syntax Highligher" icon at this forum, and paste in the code, choosing the style (Fortran, C, etc.).
You can edit your previous posts to alter text or to improve readability.
abhimodak
Hi Terry
Check this post: http://software.intel.com/en-us/forums/showthread.php?t=75442&o=a&s=lr
I think this is a known issue.
Abhi
