WINNT 4.0 service program
stober123
I am running into some trouble understanding what is required to use the ADVAPI32 function: StartServiceCtrlDispatcher(..)
The arguement to the routine is a service table entry type. Which I believe is 2 integer pointer types. The first is a pointer to a character string(C string) containing the name of the service as defined in the service control managers table(I have successfully gotten the service definition setup in the SCM). The second is a pointer to the subroutine that will perform the actual services.
My application is failing with memory access violations.
Here is a bit of the application code:
PROGRAM schedtest
USE DFWINTY
USE ADVAPI32
INTEGER(BOOL) SSCDispatcher
TYPE(T_SERVICE_TABLE_ENTRY) ServiceStartTable
CHARACTER*10 PROG
EXTERNAL SCHEDSTART
INTEGER*4 PP
POINTER(PP,SCHEDSTART)
DATA PROG/'testsch01'C/
ServiceStartTable%lpServiceName = LOC(PROG)
ServiceStartTable%lpServiceProc = PP
OPEN(15,FILE='C:TEMPSERVICE.DAT',ACCESS='APPEND', IOSTAT=IER,
& FORM='FORMATTED',STATUS='UNKNOWN')
IF(IER .EQ. 0)THEN
WRITE(15,*)' GOT TO THE main ROUTINE'
CLOSE(15)
ENDIF
SSCDispatcher = StartServiceCtrlDispatcher(ServiceStartTable)
IF(.NOT. SSCDispatcher)THEN !PROBLEM
IF(IER .EQ. 0)THEN
WRITE(15,*)' error at 1'
CLOSE(15)
ENDIF
ENDIF
STOP
END
SUBROUTINE SCHEDSTART(PARGCOUNT, PARGDATA)
USE DFWINTY
USE ADVAPI32
USE DFLIB, ONLY: SLEEPQQ
INTEGER*4 START,CRATE, MAXC, WAIT, RTIME, FINISH
LOGICAL RUN
INTEGER*4 PARGCOUNT, PARGDATA, SERVSTATHANDLE !POINTERS
TYPE(T_SERVICE_STATUS) SCHEDSTATUS
INTEGER(BOOL) SSSTATUS
EXTERNAL SCHEDHANDLER
INTEGER*4 PP !POINTER ????TRYING THIS
POINTER(PP,SCHEDHANDLER)
COMMON /CONTROLS/ RUN, SERVSTATHANDLE, SCHEDSTATUS
IF(IER .EQ. 0)THEN
WRITE(15,*)' GOT INTO THE SCHEDSTART ROUTINE'
CLOSE(15)
ENDIF
SCHEDSTATUS%dwServiceType = SERVICE_WIN32_OWN_PROCESS
SCHEDSTATUS%dwCurrentState = SERVICE_RUNNING
SCHEDSTATUS%dwControlsAccepted = SERVICE_ACCEPT_STOP
SCHEDSTATUS%dwWin32ExitCode = 0
SCHEDSTATUS%dwServiceSpecificExitCode = 0
SCHEDSTATUS%dwCheckPoint = 0
SCHEDSTATUS%dwWaitHint = 0
SERVSTATHANDLE = RegisterServiceCtrlHandler('UOPSCHED'C,
& PP)
IF(SERVSTATHANDLE .EQ. 0)THEN !PROBLEM
ENDIF
SSSTATUS = SetServiceStatus(SERVSTATHANDLE, SCHEDSTATUS)
I suspect that pointer to the service main routine is invalid, any ideas on how to pass this routine name in that structure as required?
A C++ programmer has also advised that the arguement to the startservicectrldispatcher is supposed to be a pointer to an array of pointers ending in two null values....any comments on this or how to implement?
Steve
your text hereyour text hereyour text hereyour text here
james1
Note that your program appears truncated, you might try attaching it using this forum. Anyhow regarding the routine pointer, eliminate the POINTER statment and PP variable and just use LOC(procedurename).
James
stober123
Thanks for the help, that change made it operational.
Steve
