Warn interfaces bug
nvaneck
It doesn't work properly if the file is freeform and lines exceed maximum line length for fixed form. Generates lots of false errors (In my case, hundreds). For example, if a variable type statement exceeds fixed form max length, it thinks all variables mentioned beyond max length are not explicitly typed, thinks some are unused if name is split across the max length boundary, etc. In other words, it ignores all characters past the maximum fixed form line length.
lklawrie
I think you need to supply a short program code to support this statement. Sounds really odd.
It does sound odd, but it's a real problem - our issue DPD200175196. It happens only if you also ask for standards checking. It has been fixed for a future release - see also http://software.intel.com/en-us/forums/showthread.php?t=97331
nvaneck
Steve, that's nice to know; I'll turn off standards checking so I see the interface warnings without invalid stuff. Thanks!
Of course, you could also continue those long lines so that they are standard-conforming.
nvaneck
Yes, but they are so convenient, especially with a wide-screen monitor, and keeps the code less cluttered looking.
This was fixed in the 13.0 compiler.
