29381 Discussions
Warning #5194: Source line truncated.
OP1
New Contributor III
I am getting a lot of messages of the type:
longfilename.i90(1): warning #5194: Source line truncated.
Line 1 of such intermediate file looks like:
# 1 "longpath\longfilename.F90"
and it exceeds the 132-character-per-line limit.
The rest of the code inside the intermediate i90 file is ok (I make sure to never exceed the 132-character limit) - it's just the first line inserted by the preprocessor that violates this constraint.
Is there anything to worry about here?
I would not expect to see that warning if the compiler was treating the .i90 as free-form source.  It would be interesting to also add the source listing option and check out the list of compiler options at the bottom.
OP1
New Contributor III
After digging a little further: this only happens because I have both /stand:f15 and /warn:truncated_source options, when fpp-ing and compiling a free-form F90 file.
The message sounds rather benign (after all the only thing being truncated in the file is not relevant from a source standpoint).
I can't reproduce a problem using those switches, but if it doesn't bother you then we can drop it.
