29383 Discussions
Warning #6379: The structure contains one or more misaligned fields
chauvjo
The following derived type definition generates the warning: warning #6379: The structure contains one or more misaligned fields
 type table_format
      sequence
      real(kind=dp), dimension(:), ALLOCATABLE :: array_data
      real(kind=dp)    :: aa
      real(kind=dp)    :: bb
      real(kind=dp)    :: cc
      integer(kind=i4) :: nn
      integer(kind=i4) :: kk
      integer(kind=i4) :: jj
      character(len=52) :: title
   end type table_format
Can someone explain how to align the fields of this derived type?  Does the use of the keyword "sequence" provide a performance benefit by storing all the derived type elements in adjacent memory location or do I not understand how to use sequence? In other words, should I not be using sequence?
Thanks....
The problem here is that the descriptor for the allocatable array isn't a multiple of 8 bytes, so it causes the real(dp) components to be misaligned when compiled for 32-bits.
Move that component to after the real and integer components.
Don't use SEQUENCE - it hurts performance in some cases by preventing the compiler from naturally aligning the components.
