Warning 7951 on open statement
van_der_merwe__ben
New Contributor II
For the following code:
      INTEGER UNIT,RECL,IOSTAT,iu
      CHARACTER FILE*(*),STATUS*(*),ACCESS*(*),FORMAT*(*),CSTAT*20
         ELSEIF ( CSTAT.EQ.'NEW' ) THEN
            OPEN(UNIT=UNIT,STATUS=CSTAT,FILE=FILE,ACCESS=ACCESS,
     +      FORM=FORMAT,SHARE='DENYWR',IOSTAT=IOSTAT)
         ELSEIF ( CSTAT.EQ.'UNKNOWN' .OR. CSTAT.EQ.'MODIFY') THEN
     +      FORM=FORMAT,SHARE='DENYWR',IOSTAT=IOSTAT,
     +      BUFFERED='YES',BLOCKSIZE=8192,BUFFERCOUNT=500)
The compiler says:
warning #7951: The STATUS= specifier has the value SCRATCH, the FILE= specifier will be ignored in the OPEN statement.   [FILE]
So that makes me think I can fix this by simply removing the ", FILE=FILE" portion since it will be ignored, but then all sort of runtime errors ensue that do not happen otherwise?
So what is the proper way of fixing the code to not have this warning?
van_der_merwe__ben
New Contributor II
It looks like it doesnt like the CSTAT variable, so using the explicit string instead of variable seems to make it happy:
         IF ( CSTAT.EQ.'SCRATCH' ) THEN
            OPEN(UNIT=UNIT,STATUS='SCRATCH',ACCESS=ACCESS,FORM=FORMAT,
     +      IOSTAT=IOSTAT)
            OPEN(UNIT=UNIT,STATUS='NEW',FILE=FILE,ACCESS=ACCESS,
            OPEN(UNIT=UNIT,STATUS='UNKNOWN',FILE=FILE,ACCESS=ACCESS,
Steve_Lionel
It is much more useful if you can post a small but complete source that demonstrates the problem, rather than forcing people who want to help you to add missing pieces and hope they guessed right. It's often the case that posting only snippets omits crucial information. I'd also ask that you stop using fixed-form source if you are doing new development.
That all said, I can't reproduce this problem in the current compiler version. I have a faint recollection of something similar many years ago.Which compiler version are you using?
van_der_merwe__ben
New Contributor II
Lionel, you are correct, my apologies! For new development we do use F90. We are using:
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.5.281 Build 20190815
I shall have a go at reproducing a small stand alone example, but it looks like explicitly using a string for STATUS rather than a variable avoids the warnings.
Steve_Lionel
Here's the code I tested (I used free-form):
subroutine foo (FILE, STATUS, ACCESS, FORMAT, CSTAT)
            OPEN(UNIT=UNIT,STATUS=CSTAT,FILE=FILE,ACCESS=ACCESS, &
         ELSE IF ( CSTAT.EQ.'UNKNOWN' .OR. CSTAT.EQ.'MODIFY') THEN
           FORM=FORMAT,SHARE='DENYWR',IOSTAT=IOSTAT, &
           END IF
           END
van_der_merwe__ben
New Contributor II
Attached is a VS2019 solution which shows this in the output window:
1>Console1.f
1>F:\test2\Console1\Console1.f(12): warning #7951: The STATUS= specifier has the value SCRATCH, the FILE= specifier will be ignored in the OPEN statement.   [FILE]
1>F:\test2\Console1\Console1.f(15): warning #7951: The STATUS= specifier has the value SCRATCH, the FILE= specifier will be ignored in the OPEN statement.   [FILE]
And yes, for any new development we definitely use free form! This is old code where I have always been meaning to clean up that warning.
van_der_merwe__ben
New Contributor II
The warning seems to be falsely triggered, and can be avoided by using an explicit string for STATUS instead. BTW: I also had trouble making the warning appear in the standalone code, not sure exactly what triggers it.
andrew_4619
In your example the CSTAT is a local variable that is not initialised  and the compiler can see that it is a null string. Your code has an error set cstat='scratch' .or some other valid value.
van_der_merwe__ben
New Contributor II
This little snippet should be above the first IF:
      IU = INDEX(STATUS,'_')
	IF(IU.GT.0) THEN
	   CSTAT = STATUS(:IU-1)
	ELSE
	   CSTAT = STATUS
	ENDIF
The warning appears regardless.
van_der_merwe__ben
New Contributor II
The full real function also has a number of other OPEN statements using STATUS where there is no warning.
van_der_merwe__ben
New Contributor II
Here is the project with the snippet added, the warnings are still there.
andrew_4619
deleted
andrew_4619
This gives the error for line 10 but if I comment out lines 7 & 8 the error goes away so I think maybe it is a parsing bug in the compiler or something like that. It may also relate to having a variable called status which is a Fortran keyword...
      SUBROUTINE MOPEN (UNIT,FILE,STATUS,ACCESS,FORMAT,RECL,IOSTAT)
      CSTAT = STATUS
     +      IOSTAT=IOSTAT)
         ENDIF
      END
van_der_merwe__ben
New Contributor II
Andrew, I agree, I have often glanced at that code and warning and thinking "what? why?". I have logged this as a bug with intel,request number 04505944. I can avoid it by explicitly using a STATUS string, so this is minor.
andrew_4619
Line 6 triggers the warning on line 8
      SUBROUTINE MOPEN ()
      CHARACTER FILE*20
      character CSTAT*20
      CSTAT = 'NEW'
          OPEN(UNIT=22,STATUS='SCRATCH')
          OPEN(UNIT=22,STATUS=CSTAT,FILE=FILE)
      ENDIF
      END
jimdempseyatthecove
I haven't experimented with the code, as for an observation, what happens when you use:
       ...,STATUS=TRIM(CSTAT),...
Jim Dempsey
FortranFan
@van der merwe, ben:
Note the standard says
 9    12.5.6.18 STATUS= specifier in the OPEN statement
10 1 The scalar-default-char-expr shall evaluate to OLD, NEW, SCRATCH, REPLACE, or UNKNOWN.
So line 16 in your code can be non-conforming if CSTAT evaluates to 'MODIFY'.
You can suppress diagnostics if you so choose using /Qdiag-disable compiler option:
https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-diag-qdiag
Or you can edit your code like so:
      CSTAT = STATUS
      IF ( RECL.GT.0 ) THEN
      ELSE
     +      IOSTAT=IOSTAT)
         ELSEIF ( CSTAT.EQ.'UNKNOWN' .OR. CSTAT.EQ.'MODIFY' ) THEN
         ELSEIF ( CSTAT.EQ.'OLD' ) THEN
            OPEN(UNIT=UNIT,STATUS='OLD',FILE=FILE,ACCESS=ACCESS,
     +      FORM=FORMAT,SHARE='DENYWR',ACTION='READ',IOSTAT=IOSTAT)
         ELSEIF ( CSTAT.EQ.'APPEND') THEN
            OPEN(UNIT=UNIT,STATUS='UNKNOWN',FILE=FILE,ACCESS='APPEND',
         ENDIF
      ENDIF
      RETURN
      END
andrew_4619
@@FF This gives the warning there is no connection to the non-conformance in the OP code.
      SUBROUTINE MOPEN ()
      CHARACTER(20) :: myFILE = 'fred.txt'
      character(20) :: CSTAT  = 'NEW'
      !character(20), parameter :: CSTAT='NEW' ! this ILO the line above eliminated the warning
      OPEN(UNIT=22,STATUS='OLD')
      OPEN(UNIT=23,STATUS=CSTAT,FILE=myFILE)
      END
andrew_4619
And finally because I have lost interest now this is the minimal reproducer in free format
SUBROUTINE MOPEN2 ()
      !character(20), parameter :: CSTAT='NEW' ! this line ILO the line above eliminates the warning
      OPEN( UNIT = 22, STATUS = 'OLD') ! if this line is commented out there is no warning for the next line
      OPEN( UNIT = 23, STATUS = CSTAT, FILE = 'fred.txt' )
      ! above line gives warning #7951: The STATUS= specifier has the value SCRATCH, the FILE= specifier will be ignored in the OPEN statement.   ['fred.txt']
END
FortranFan
andrew_4619 wrote:
@@FF This gives the warning there is no connection to the non-conformance in the OP code. ..
OP shared code which used literal constants such as 'SCRATCH' and 'OLD' with STATUS= specification on certain lines but the variable CSTAT on some other e.g.,
      CHARACTER .. CSTAT*20
      CSTAT = STATUS
So my suggestion is to either suppress the warning if it's bothersome to OP, or to modify the code line that has 'STATUS=CSTAT' with a literal constant like on other lines.  But then STATUS='MODIFY' won't be conforming per Fortran standard, so OP will have to decide whether to go with the literal 'UNKNOWN' in that case.
The code in Quote #17 doesn't generate the warning.
C:\Temp>type Console1.f
      CSTAT = STATUS
      ELSE
     +      IOSTAT=IOSTAT)
         ENDIF
      ENDIF
      RETURN
      END
C:\Temp>ifort /c Console1.f
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
Console1.f(13): warning #7951: The STATUS= specifier has the value SCRATCH, the FILE= specifier will be ignored in the OPEN statement.   [FILE]
Console1.f(16): warning #7951: The STATUS= specifier has the value SCRATCH, the FILE= specifier will be ignored in the OPEN statement.   [FILE]
C:\Temp>type modified-Console1.f
      CSTAT = STATUS
      ELSE
     +      IOSTAT=IOSTAT)
         ENDIF
      ENDIF
      RETURN
      END
C:\Temp>ifort /c modified-Console1.f
C:\Temp>
andrew_4619
Workarounds are easy, but not withstanding any issues with the OP's code (not least the considering that fixed format makes my eyes bleed) primary issue is a bug in the compiler.
