Warning messages
lxh37
I installed composer_xe_2015.3.187 and tried to generate .dylib in Mac Yosemite. After I compiled Fortran codes (no error)
tried to generate the .dylib file using this command:
/opt/intel/bin/ifort -static-intel -dynamiclib -openmp *.o -o libsamplesize.dylib
I got warnings:
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal9FreeBlock12minBlockSizeE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal13BackRefMaster6dataSzE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal5Block16emptyEnoughRatioE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal18minLargeObjectSizeE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal10MemoryPool18defaultGranularityE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal28RecursiveMallocCallProtector10autoObjPtrE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal28RecursiveMallocCallProtector12owner_threadE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal9hugePagesE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal28RecursiveMallocCallProtector9rmc_mutexE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal28RecursiveMallocCallProtector23mallocRecursionDetectedE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
ld: warning: can't find atom for N_GSYM stabs __ZN3rml8internal10MemoryPool15memPoolListLockE in /opt/intel/bin/../composerxe/bin/../../composer_xe_2015.3.187/compiler/lib/libiomp5.a(iomp.o)
I have generated .dylib using exactly the same source codes and don't have those warning messages in previous version of compiler, wonder if
I should fix anything or ok to ignore them?
Thanks!
liz
