Watch DLL variables
onkelhotte
New Contributor II
Hi there,
in my project I havetwo DLLs and a main program. One DLL only contains a sharedVariablesmodule, the second DLL initialises the sharedVariables and the main program uses them.
But now I cannot watch the sharedVariables in the debugger, although they are used correctly (i.e. by writing their value ina textfile).
sharedVariables::alpha for example is evaluated as "Undefined variable", the tool tip while moving the mouse over alpha says3.6433238E-29.
Is there a way to watch these values in debugger? I use IVF10.1.025.
Thanks in advance,
Markus
PS: This is why I use thetwo DLL and main program mechanism: Before thatI read a textfile which contained the start values. To preventthe customer can edit this textfile, I wrote a subroutine that initialises the variables. Because I want to be able to substitute these intial values I create a DLL that I could send the customer.
Creating a MD5 hash of the textfile wont do the trick because the MD5 would be different when I manipulate the textfile.
onkelhotte
New Contributor II
PPS: This is how I declare Alpha in the module sharedVariables...
real(kind=4) :: Alpha
!DEC$ ATTRIBUTES DLLEXPORT :: Alpha
In my main program I dont use the DLLIMPORT attribute because it is not neccesary. Alpha is declared in a module and so the DLLIMPORT is absolete.
Markus
Try version 11, or at least 10.1.029. We have made improvements in "watching" since 025. 11.0.066 would be my recommendation.
onkelhotte
New Contributor II
My licence expired shortly after 10.1.025, so I have to renew it... Not I by myself but my boss (like every boss)doesnt want to spend extra money :-)
By the way, is this error fixed in the latest IVF version?Tool tip of german Umlaute freezes debugger http://software.intel.com/en-us/forums/showthread.php?t=58552
I just locked in into the Registration center to find out the price for a renewal of my lincense. I have Fortran with MKL right now. I was confused that there is a buy link at the Intel Compiler Suite as well (but not at the Fortran with IMSL version). Can I upgrade to the Compiler Suite through a support renewal?
Markus
I believe that the umlaunt problem will be fixed in an update later this month. No, you can't change products using a support renewal. I know some companies offer that sort of upgrade but we don't at present. The Compiler Suite product is not offered with IMSL.
I'm not entirely certain of what you are seeing at the Intel Registration Center. Perhaps you can use the "Live Chat" feature there to get assistance.
onkelhotte
New Contributor II
I renewed my license, but I still cant watch variables that were declared in a DLL (IVF 11.0.072).
Is this still on the IVF Integration Teams to do list?
The other problems Ive had in the past (umlaut freeze, crash when watch var*2.1) were fixed, thanks for the good job!
Markus
The watch issues should be fixed, but you have to rebuild the appliication. It isn't just the debugger.
onkelhotte
New Contributor II
No, I cant watch this variable. My code looks like this:
[cpp]module sharedDLL
implicit none
real(kind=4) :: variableInDLL = 0.5
!DEC$ ATTRIBUTES DLLEXPORT :: variableInDLL
end module sharedDLL[/cpp]
But when I try to watch the value of variableInDLL, it says 2.5305179E-29. When I assign the value to the variable runTime, runTime has the value 0.5
Markus
Does watching sharedll::variableinDLL work?
onkelhotte
New Contributor II
No. In that case the value is "Undefined variable sharedDLL::variableInDLL".
Markus
onkelhotte
New Contributor II
With release 74 of IVF11 it works!
Thanks for adding this feature.
Markus
